The Truth About Tools
Old Aug 7, 2001 | 04:03 PM
25thRS's Avatar
Thought you guys would enjoy this. :-)
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing seats and motorcycle jackets.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling mounting holes in fenders just above the brake line that goes to the rear wheel.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the original sin principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire. Also handy for igniting the grease inside a brake drum you're trying to get the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16" or 1/2" socket you've been searching for the last 15 minutes.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your coffee across the room, splattering it against that freshly painted part you were drying.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouc...."
HYDRAULIC FLOOR JACK: Used for lowering a motorcycle to the ground after you have installed your new front disk brake setup, trapping the jack handle firmly under the front fender.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a motorcycle upward off a hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
Maroon '92 RS 3.1L AT PW PDL CC Tilt
Old Aug 7, 2001 | 04:23 PM
Jiffy's Avatar
Well...I guess Im not the only dumbass that can't use a saw correctly.
Jeff
92 Camaro V6, mods: K&N, modified air box, JET chip 2,Dynomax Cat & Cat Back Systemwww.camarors.4t.com
Old Aug 7, 2001 | 04:34 PM
87RS402's Avatar
Don't forget the Mystery Ratchet.
A device designed to look like a harmless everyday ratchet, but once you apply and decent amout of torque to it. It slips bashing your knuckles in the sharpest piece of casting flash or jagged metal with it's trajectory.
Old Aug 8, 2001 | 09:42 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I thought I broke my elbow when I changed the fuel pump recently... I was un-doing the driver's side lower shock nut; the breaker bar slipped, I fell forward, my knuckles slammed into the pavement- and my elbow hit the brake rotor! I just lay there in the grass for 5 minutes or so until the pain went away... I suppose I looked dead to anyone driving by.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
92projectcamaro
Dec 8, 2015 12:25 AM
Reid Fleming
Oct 10, 2015 09:56 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
ULTM8Z
Sep 16, 2015 09:15 AM
mrdevontay
Sep 2, 2015 08:04 PM
