belt tensioner
Old Aug 8, 2001 | 12:11 PM
brn29's Avatar
belt tensioner
i've recently noticed a rattle/knock coming from the front of my engine while running. i believe it to be the belt tensioner. my question is: is there supposed to be any 'back-and-forth' movement of the pulley? while the engine is running, the pulley is moving back and forth slightly. the pulley seems to be rotating ok, but it moves back and forth some and makes a small rattle/knock; moreso when the a/c is on.
the belt was changed approx. 3 months ago (approx. 5k miles).
thanks for any input. also, if it needs to be replaced, does anyone have the part no.? i've check at a few dealers for prices, but none will give me a part no.
Old Aug 8, 2001 | 12:13 PM
Ovrclck350's Avatar
I had to replace mine Friday. I believe it's a dealer only item, and mine ran me $40.10 after tax. Mine used to rattle, then all of a sudden, it just went out. If you suspect it's goin out, I'd replace it, otherwise you might end up buying a new belt too.
Old Aug 8, 2001 | 12:19 PM
brn29's Avatar
i forgot to add.........it's a 1992 rs, 3.1 v6.
thanks
Old Aug 8, 2001 | 12:35 PM
Ovrclck350's Avatar
92 Bird 3.1, so it'd be the same.
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
anesthes
Sep 30, 2015 07:48 AM
kitt23
Sep 26, 2015 07:48 PM
