Ghetto Ram Air idea - for firebirds
Old Aug 10, 2001 | 01:10 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
ok, it might be really really ghetto, but i have an idea. take the top of the filter box off and then put a funnel on top (to seal dirty air from clean air). cut the funnel to about 3" opening and then run a pvc pipe behind the radiator, down and then into the air dam, any ideas??? comments??? o and it would be smog legal cuz u keep the filter box and put it back 4 a smog test.
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
New Pioneer Head Unit
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
Old Aug 10, 2001 | 08:49 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Is there room to run the PVC? Sounds like you want it between the airbox and the hood... or did I read that wrong?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Aug 10, 2001 | 12:32 PM
89V6FBIRD's Avatar
well take the filter lid off, and then that will give some clearance, then run some sorta pvc pipe in the space between the radiator and coolant reserve tank. if i have to, i'd get a shorter filter, or taller, whichever works. sorry if the pic confused you, but i dont have a pic w/o the filter box lid.
[This message has been edited by 89V6FBIRD (edited August 10, 2001).]
Old Aug 14, 2001 | 03:31 AM
89V6FBIRD's Avatar
well I just noticed that pvc won't fit thru that gap between the coolant reserve tank and the radiator, so I wanna try dryer duct and then maybe a ghetto air scoop (which would be an exhaust fan vent that would look really good as an intake scoop)
Old Aug 14, 2001 | 08:30 AM
KED85's Avatar
Looking at your pic, vision this.
This is what I have decided to do.
Take the top lid.
See that air inlet?
Flatten it.
I used a heat gun to form it into shape.
Air now enters above the radiator support.
BUT, what's in the way?
If ya look further, there is a brace, on the hood, that cuts air flow. Right by the rubber piece on the hood, that supports the correct height of the hood, when it is closed.
I am taking a cutting wheel to that area.
Cutting two openings in that brace, leaving a support on the bottom.
I'm taking the turn signal and turing it into an air scoop.
I have a spare lid (I've already done the heat gun trick to it) a spare turn signal that I have to create into the air scoop. Then cut the hood brace.
In the process of turning the turn signal into a air inlet, I have to recreate a functional turn signal part, also. Part of the fun, with a saw and JB Weld.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Sep 7, 2015 01:37 PM
perZ
Aug 15, 2015 01:17 PM
mustangman65_79
Aug 11, 2015 03:17 PM
bryan623
Aug 10, 2015 11:33 AM
