FRONT-END/STEERING LINKAGE ???NEED REPLIES ASAP!
Old Aug 13, 2001 | 10:10 PM
squirrelybird's Avatar
Problem: My car gets the bad shakes 60mph plus.
so... today I took it to get the tires rebalanced and they were fine. Then the guy showed me that when the steering wheel is held straight (on a lift) you can wobble the front wheels around. He said I could have a problem with a steering part. The real problem is that I leave for a 2 hour drive to college on saturday 8/18 so I need this fixed A.S.A.P!!! How do I diagnose it? Can I fix it? How much $$ should I expect to dish out???
I checked it out and everything moves from the balljoint studs(?)down. This is where the inner tierods connect to the idler arm and pitman arm. What needs replaceing? Can I do it? How much mula?
Old Aug 13, 2001 | 11:18 PM
KED85's Avatar
really?
For the parts, kinda little.
As low as maybe $15 to $100+ for some.
Then the labor, + alignment.
Could be loose bearings.
Who has worked on it?
Has it ever been done?
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Aug 14, 2001 | 12:03 AM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
Shaking/shimmying at crusing speeds (and not being tire balance) sounds alot like a bad center link. That is the part that the inner tie rods, idler & pitman arm connect to. And, if your going to replace that, you might as well rebuild the front end since the other parts attatch to it.
Ya can't have too many fast Chevys!
Old Aug 14, 2001 | 09:22 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, the center link and the idler arm are common "wear" items- meaning, they wear out on our cars. I had mine changed out a few years ago, and wow, what a difference...
-Tom P (Hot rodded 1986 Firebird 2.8l)
Lbibb
May 5, 2016 12:00 AM
86White_T/A305
Mar 6, 2016 01:48 PM
mattcanty
Oct 12, 2015 11:08 AM
mfp189
Sep 27, 2015 09:25 AM
92projectcamaro
Sep 24, 2015 08:09 AM
