I just bought a T-5.......wasn't planning to but....
Old Aug 11, 2001 | 11:27 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
I saw it at the boneyard and said "what the hell, i'll pull it out". Sort of an impusle buy. I guess i'll be doing the good ol' 700R4- T-5 swap eventually.....not soon though.
I couldn't get the goddamn flywheel off though. Plus, somebody already snagged the slave cylinder and the pedals. Guess i'll have to search for that stuff.
Does anyone know how long a Standard transmission actually lasts? I mean you hardly ever hear of one being rebuilt, unlike auto's which are rebuilt often. I got this one from a 85-87 Firebird. (It had MPFI but didn't have a serpintine belt, what years were these?)
Also, Graeme, exactly where was cutting required and what did you use to cut? Maybe i could take a look at your car since you've been through this. Are you having any problems?
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Old Aug 11, 2001 | 11:28 PM
KED85's Avatar
DAN, YOU HAVE A 700R4 TRANNY FOR SALE??
Talk to me!!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Aug 12, 2001 | 12:14 AM
Engine: LH0 3.1L
Which one? The boneyard one or the one that's in my car? The boneyard one is probably gone. I swiched jobs and left it behind. It was in a million peices though, and i couldn't get it back together. Sorry... BTW, you planning on painting the Bird? Oh, and if you see and slave cylinders or clutch pedals at the yards let me know.
Old Aug 12, 2001 | 11:23 AM
86Chicken's Avatar
I also have a 700R4 for sale. $50 plus shipping. Worked well before the tranny swap now it is just sitting in my garage. info@myfirebird.com
I know that I am not supposed to post this stuff but I really need to get rid of this tranny, it weighs too much to just keep dolly-ing it around the garage.
Dale
1986 FireBird
2.8L MPFI
Gutted Cat, No muffler (Sweet Sound)
Was 700-R4 --> Now T5
Old Aug 12, 2001 | 12:40 PM
KED85's Avatar
Would both Dan & Dale get ahold of me at my email address accessable here?
OH YES, I am VERY interested!!
THANKS!!!
Chat Soon,
KED85
Karl
Old Aug 12, 2001 | 11:47 PM
AntiVTEC's Avatar
My T-5's got 193k miles on it. Its getting slightly harder to shift into second but nothing that you cant live with. Personally, I think the thing is rock solid considering how much hell i put it through. You know, drag racing, road racing, powershifing, standstills... stuff like that. It also could be that my motor just doesnt have much power to break it anyway.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro.
Old Aug 12, 2001 | 11:52 PM
Engine: LH0 3.1L
Cool, the donor car had 146,000 on it and it was a 1985 or 86 model. Fluid was clean. Hopefully i'll have no probs with it.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Old Aug 13, 2001 | 05:50 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
<font face="Verdana, Arial" size="2">Originally posted by AntiVTEC:
</font>
be careful dude, mine was like that at 170,000 miles, it was hard to shift into 3rd gear, sure enough, one nite it went into 3rd gear and never came out (until i had the tranny rebuilt for $1600)
Old Aug 13, 2001 | 10:21 AM
86Chicken's Avatar
Rebuilding a T5 is not that big of a project to do yourself For someone who has done it before it should take at MOST 7-8 hrs and 200 for parts. It took me about 12-15 hrs but I had never even seen the inside of manual tranny before. Just grab an older Chiltons or GM Service book and go to it.
Old Aug 13, 2001 | 10:46 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I agree about the ease of rebuild... it will cost a fortune at a good shop, but that's mostly lifting the engine, taking it out and sitting around whacking off expense... It should be relatively quick if you have it out and sittin' around... I would say 250k-300k for a reasonably well taken care of Tranny, possibly less if the little old lady that used it before knew nothing about how to shift. I don't know how well built the T-5 is though, but I've never had a tranny quit on me... speaking of manual cars with 117k, 213k and 315k on them. I would say the clutch should be installed new as those will last from 80k to 400k depending... I've got 140k on the bird and the tranny is smooth as silk with no play whatsoever.
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, Goodyear P215/60/R16, AIWA bargain basement (from Sears of course) CD player, Fuzzy dice, Eight-ball shift ****
Check out my ride here
First Kill: 2001 Subaru Impreza WRX Wagon (1 person vs me with 2 passengers)
[This message has been edited by ChillPhatCat (edited August 13, 2001).]
Old Aug 14, 2001 | 11:14 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
The hardest thing was getting a correct clutch to work with my input shaft... (not a problem u will have ) i used a plasma cutter to cut the hole for the shifter.. and regular old drill bits for the master to go through the firewall.. the location on that is DIRECTLY under the brake booster
1989 Firebird
2.8 v6, t5 swapped in
Performance Mods:
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Car Stereo:
Blaupunkt head, Monster Cable wiring, MTX Thunder 6000 12" inverted in a personally made box with a 350*1 Amp pushing it, MTX 6x9 in the back with hopes for components in front
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
My Site:
Click Here to see my car!
Old Aug 15, 2001 | 01:46 AM
Ovrclck350's Avatar
I think the reason that you don't hear of as many problems with standard tranny's is that the clutch isn't that hard to change out, and usually when an automatic goes out, it's the clutches that are slipping, right? That's why you here more about auto's, cuz they're a b*tch to replace.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
86IROC112
Sep 7, 2015 01:37 PM
firebirdta84
Interior Parts Wanted
Aug 30, 2015 09:28 PM
pimprs
Aug 24, 2015 11:20 PM
johanlindgren
Aug 16, 2015 12:16 AM
