mpfi v6 acceleration problems
Old Aug 5, 2011 | 10:11 AM
86camaro17's Avatar
Transmission: manual
I have a 1986 sport coupe v6 and when i turn and put into second and accelerate the car pauses makes a knocking or clicking noise and then after the pause it accelerates. It happens in 3rd as well. I have recently done the transmission, radiator, clutch, belts and hoses, and am thinking it could be spark plugs because they have never been done. any ideas?
Old Aug 5, 2011 | 12:02 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: mpfi v6 acceleration problems
Do a full tune up (plugs, wires, filters, PCV valve, all fluids, distributor cap and rotor) and then let us know what happens.
Old Aug 5, 2011 | 02:47 PM
86camaro17's Avatar
if i had the money. i would do everything. but im trying to specify before i do work
Old Aug 5, 2011 | 05:19 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
You sure its not just low on gas? these cars have an annoying habbit of cutting out on turns even on like an 1/8th a tank.
Old Aug 5, 2011 | 05:42 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Did it do any of this before you 'did' anything to it?
Old Aug 5, 2011 | 06:57 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Personally, (I did so anyways), I'd just bite the bullet and squeeze out the cash for the full tune up. There really isn't anything to be specific about until you can be sure that most of the tune up parts and disposable components have been replaced (plugs, wires, cap and rotor). You can't be sure of how old the parts are unless you replaced them yourself, so it's a good idea to get new parts before trying to fix a problem that may not exist with new parts. If it still runs like junk after the tune up, then you have a problem, but at least you know it's not caused by a bad plug or wire or something.
Either way, pull a spark plug. Plugs are the best indicator of how the engine is running.
Old Aug 5, 2011 | 07:47 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
rockauto.com has some good deal, got a new coil n ICM for $30 shipped.
Old Aug 5, 2011 | 11:16 PM
86camaro17's Avatar
true. i always am low on gas. that could definitely be it. but the car feels much slower than when i first got it
Old Aug 6, 2011 | 05:55 AM
Engine: 3.8, 3.4
Put half a tank in it and see if it still cuts out on you. If it feels slower it probably just needs a tuneup.
Old Aug 6, 2011 | 11:27 AM
86camaro17's Avatar
alright
Old Apr 9, 2012 | 07:27 PM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
lol. Yeah cars pretty much like to have gas.
I did hear that someone somewhere made a fuel pump for our cars that would kinda move with the g-force of the car to avoid fuel starvation. I wish I could find one.
Old Apr 10, 2012 | 12:10 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
^ you put a sweeping pick up tube like you can do for the oil pick up, it will move with the movement of the fluid.
Old Apr 10, 2012 | 07:31 AM
Damnit why didn't I think of that? Having a blonde moment.
Now next time my wife wants to go shopping, I have the excuse, no...I gotta drop the gas tank and put a sweeping pickup on the fuel pump. ( I already told her I needed to replace the chrome-reversed muffler bearings to avoid going to my anger management meeting )
BirdonFire
Jan 2, 2002 08:19 PM
Birmass
Dec 7, 2001 11:52 PM
87_Camaro
Aug 29, 2001 04:49 AM
BadBowTie
Apr 12, 2001 03:03 PM
Terry720
Feb 8, 2001 07:04 AM
