swapping 2.8 block and heads for 3.4 question
Old Aug 10, 2011 | 08:30 PM
barrentinec's Avatar
Car: 89 Firebird
Engine: 2.8 v6
Transmission: 5 speed Manual
i have been reading a lot on here about swapping my bad 2.8 block and heads for a 3.4 block and heads. i printed out several different post on here about doing it and am pretty confident i have it down. there is just one issue i have with it. before my 2.8 went i had installed the pacesetter headers on it. i cant find anything in here about if they will transfer over to the 3.4 block or not. i cant understand why they wouldn't just want to check and make sure. they were only on the 2.8 for a month or so would hate to no be able to use them anymore. plus i like the sound of my current exhaust setup.
Old Aug 10, 2011 | 08:36 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: swapping 2.8 block and heads for 3.4 question
You should have been able to find about a million and 2 posts about that..
Yes, they will fit.
Old Aug 10, 2011 | 08:38 PM
Car: 89 Firebird
Engine: 2.8 v6
i did find a ton of posts on doing the swap but no one mentioned the headers at all. i figured there wouldnt be an issue just wanted to make sure before i start.
Old Aug 10, 2011 | 08:45 PM
I've seen swapping headers mentioned many times, between 2.8, 3.1 and 3.4.
Just bolt them up.
Old Aug 10, 2011 | 09:51 PM
Guest
Guest
Posts: n/a
Why wouldn't they work? The heads are the exact same, the block deck height is the exact same, the block re-uses the 2.8 mounting, et cetera. If you didn't realize these facts, then you didn't do enough reading.
Old Sep 1, 2011 | 03:58 AM
crazybird's Avatar
Car: 1987 firebird
your a jerk.
Old Sep 1, 2011 | 01:11 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
He is not a jerk. If you have researched the 2.8/3.1/3.4 swap, you would know that the heads and block are dimensionally-at least externally- the same, so all the accessories will bolt on, INCLUDING THE EXHAUST. If you have researched that and still ask this question, then you did indeed not do enough reading. Plus this has been asked and answered a bazillion times on this site...
Old Sep 1, 2011 | 02:03 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Originally Posted by crazybird
your a jerk.
You're
Old Sep 1, 2011 | 06:34 PM
LOL...
Ok, lets get back on track before I have to lock this thread.
Old Sep 1, 2011 | 08:49 PM
Fallen2603's Avatar
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
But...grammar is IMPORTANT!
Old Sep 1, 2011 | 09:29 PM
Guest
Guest
Posts: n/a
Looked to me like a simple case of bad spelling.
Old Sep 2, 2011 | 07:29 AM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
It was both a spelling and grammar mistake. A two-for-one.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
