Rebuilt the M/c, and got brakes back!
Old Aug 30, 2001 | 10:02 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The M/c rebuild was easy, but messy... and I have no idea why it was leaking from the rear seal. I expected to see a torn seal, but it was fine. The bore was smooth, too. There was a little notch in it, but it was smooth (probably honed by the rebuild company), and there was no matching "rip" in the old piston's rear seal. I did notice though that the new primary piston (in the rebuild kit) rear seal looked like an o-ring, whereas the one I pulled from my car was flattened. Maybe the one from my car suffered the same fate as the distributor o-ring- ages, flattens, and leaks. I snagged two pics of the rebuild; they'll go up on my site (when ever I make one, hehe).
I never got to use my m/c pressure bleeder. I hooked it up to the rebuilt m/c and gave it pressure; it was working good until my bleeder bottle ran dry, and I forced air into the m/c reservoirs. Right after that, my bleeder overfilled the m/c reservoir and started leaking- so I don't know if it was because of the air forced in, or if I came up with a bad design again. So I just re-bench-bled the m/c.
I used the pressure bleeder (minus my new adapter) directly on the brake lines on the car... I hooked the bleeder bottle into the lines that come off the prop valve and go into the m/c. So I knew my brake lines (and calipers) were flushed of old fluid, and air-free...
Then I hooked the m/c right onto the car. As my GM manual seems to say, if the m/c has no air in the bore, and the car's brake lines & calipers are known to have no air in 'em, no further bleeding is necessary.
So I hooked the system up, and tried the pedal- awesome! It's higher (and firmer) than ever! And I bench-bled the m/c exactly as I did last year, too. I wonder if my theory of the "pre-rebuilt m/c's" is correct.... they sit so long in warehouses that the seals dry out.
All I need to do is get those rear calipers rebuilt with the recall/service bulletin parts, and I'll have one helluva brake system!
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Aug 30, 2001 | 11:41 AM
KED85's Avatar
Way excellent.
THE CHEAPEST AUTO INSURANCE IS THE BEST BRAKES!
Your policy is renewed!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
sailtexas186548
Jan 19, 2016 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
backtothe80s
Sep 5, 2015 12:39 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
