What will a built V6 run in the 1/4 without a power adder?
Old Sep 4, 2001 | 11:02 PM
IROCZ28TPI's Avatar
I want to know a few answers to this please.
Mike L.
1987 IROC Z 5.7 TPI A4 3.27 Borg-Warner
four wheel disc
Mods:[i] 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler,cutout. 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog, few others I forgot...???
**BOYCOTT LAPEER DRAGWAY**
Old Sep 4, 2001 | 11:24 PM
3.1 firebird's Avatar
mid 15's with good traction and weather. My car runs a 16.0, but I have a hard time getting it to hook up well since I have 3.73 non-posi. Red91bird modded his car to 14.9's and 13.9's with the juice. There was another guy here named brad keith who had a high 14 second 2.8.
you can check my sig. All I really have left to do is put a set of ported heads on. Of course there is an ignition box,roller rockers,torque converter,chip,posi,weight reduction left if I want to go all out.
1992 black 3.1 V6, auto, T-tops. dynomax catback,3.4 headers, home-made FIPK,hypertech pulleys,B&M shiftkit,3.73's,crane compucam 2030
16flat@85.6
Old Sep 4, 2001 | 11:36 PM
Jiffy's Avatar
3.1 Firebird......Do you know your 0-60 times?
Old Sep 5, 2001 | 12:25 AM
probably 9 seconds on the 0-60.
Old Sep 5, 2001 | 06:18 AM
Brian K's Avatar
We need a GP for the juice... Lets all stop playing and start sprayin.
Old Sep 5, 2001 | 09:18 AM
87_Camaro's Avatar
wow 15-16 with a V6, now i know there is hope for my car , im pretty sure with what i have right now i would at least get late 16'-17's
but soon after everythign i do i should be running 15's-16's
this coming friday im buying a Cat from Don's for 60 bucks, it's a high flow one but i forgot what it was called, wasn't catco, something like performance.
he didn't have any dynomax cat back systems in stock, here is a quick question, i can special order it an have it in 3 days, BUThe can only order V8 Cat Back system's, will the
cat bakc fit my V6? or are all dynomax catbacks made for V8's??
thanks
Old Sep 5, 2001 | 07:10 PM
Camaro_hunter_d's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 87_Camaro:
thanks
</font>
yes the V8 will for the V6. same curves and bends. Just get the 2 1/2 inch version and not the 3 inch. You will loose MAD torque due to NO back pressure.
Old Sep 5, 2001 | 09:20 PM
Jiffy's Avatar
dble post oops
[This message has been edited by Jiffy (edited September 05, 2001).]
Old Sep 5, 2001 | 09:22 PM
Jiffy's Avatar
3.1 firebird....I have another question, I checked on the cam you have in your sig and in summit it said it was only for v8s.
I have a 92 3.1 camaro and I like what you have done to your car. Could you give me the low down on the cam, because Im interested in making that my next mod.
Thanks alot
Jeff
92 Camaro V6, mods: K&N, modified air box, JET chip 2,Dynomax Cat & Cat Back System
www.camarors.4t.com
Old Sep 5, 2001 | 09:26 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Camaro Hunter- 3" didnt loose anything, i gained. In low end i did lose, but what i lost in low end i gained in top end 2x, When i first take off the line im kinda slow til about 2300, then when i hit that, i take off like a bat outta hell...
1989 Firebird. Modded.
700r4--&gt;t5 w/ram clutch
Cold air, 1.6 rockers, 21lb injectors, 3" y-pipe, random tech cat, 3" ipipe, flowmaster 80 series 3" in 3" out hand made stainless tips, Lakewood LCA's, Msd 6a, Msd coil, Wonder Bar, 180* stat,
Coming Soon: T/a hood, Painted,Spohn Panhard Bar, 4thgen Front Seats, Cam!, Msd 8.5 wires, Posi (ACCEL IS CRAP)
"I'd rather run last in a full out race, than to NOT have run at all"
See my car Here!
In Memory of #3 Dale Earnhardt
Old Sep 6, 2001 | 05:35 PM
20-psi's Avatar
What do you mean 'built V6'? Street car? Race car? Everybody that responded assumed that you meant stree car. Does anybody follow NHRA Sportsman Divisions? They have a class called Competition Eliminator that have mostly V6's and small V8's that run an index based on cubic inches vs weight. Some of the quickest cars are running V6's. I've seen them go as quick as 8.50's in the quarter.
Check out National Dragster to see the index's or go to a national event and watch the sportsman racing on Saturday and Sunday. There could be a lot of knowledge gained if you checked out some of these guys.
Pete
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
roysatikas
Sep 22, 2015 08:15 PM
Nick McCardle
Sep 10, 2015 08:36 PM
