problems with 2.8L Won't idle, weird SES light
Old Sep 10, 2001 | 09:01 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
I've got a strange problem with a 1987 2.8L v-6, the check engine light blinks in a very weird pattern, just by turing the key to the 'on' position. It will sometimes idle nicely, then immediately run poorly and won't idle, but will stay running if you open the throttle. I'm going to check the fuel filter, and it looks like all of the sensors have been replaced. Anyone with a similar problem?
thanks.
Old Sep 10, 2001 | 09:41 AM
KED85's Avatar
Follow every vacuum hose you see.
You will see you solution. Use 5/16" vacuum hose for the majority of the cracks. Use 1/4" if you can, but, most likey, it's only 5/16" and that size is large enough.
Use 1/2" vacuum hose on the fitting on the back by the base of the distributor.
Just follow you hands on a COOL ENGINE!!
PS, any hard plastic hose you touch will likey crack, just break clean and patch up with the 5/16" hose.
When I did my swap, I spent a whole day doing that.
Recently cured two major expensive items (MAS & EGR) replacements by new 5/16" vacuum hose. After you do your patch job, disconnect the battery and let it sit for 10 minutes, then start and drive it.
You should be good.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Sep 10, 2001 | 12:26 PM
jwscab's Avatar
Engine: Many
Hmmm...a vaccum leak is the likely culprit then?.....I'll start looking at that as soon as possible. It certainly sounds like that could be, the girl we bought the car from said it used to drive great, then it started to fail, so that makes sense. Thanks for the Info!
Old Sep 10, 2001 | 08:45 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Look at your IAC, it may be getting slugish. Thats what happen to me, when I checked mine it fell apart in my hands. Everytime I had my A/C on the car would die because the engine couldn't get enough air, but if you gave it some RPM or if you where driving with the butterfly open, NO problem till you got of the gas and it would stall.
Old Sep 10, 2001 | 10:43 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Check the hose between your powerbooster and intake that is a high pressure hose i took that off once and forgot to put it back on sounds like you have the exact smae problems i did.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
zeitghaist
Aug 18, 2015 07:33 AM
Omega
Aug 10, 2015 12:46 PM
