Tom(or anyone who's had this problem)?'s about any hints of a dieing fuel pump.
Old Sep 13, 2001 | 03:37 AM
Kevin S's Avatar
When your pump was going bad what kind (if any)hints did you have before complete failure?My RS doesn't seem as "peppy" anymore.
The last 2 nights at work I would start my car to have some heat inside.After 5 minutes or so it would shut off.It also takes longer to start.My better half(yeah right!)has had it stall on her at red lights,or anytime she lifts her lead foot from the pedel at very slow speeds.
I don't have a fuel pressure guage to check my pressure.Just trying to get an idea if it may be pump problems.
The next time you think your perfect,try walking on water!
Old Sep 13, 2001 | 11:39 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You might want to pick a gauge up; it will give you the final "say" of a dying pump, and might also give you warning. My car seemed fine, both times, up until the pumps died. I'll say tho, after putting a new pump in, there's a definate boost in power. I assume the drop in power was so minimal, and spread out over such a long period of time, that I didn't notice it.
Like I said, the pumps sounded odd. The first to die (original AC Delco) went from a strong "hummm" to a weak "gurgle/buzz". It sounded like it was sick. The second (and most recent, hopefully the last!) to die was a Borg-Warner pump. It went from a strong "hummm" to a Really Loud "BUZZZZZ!" It sounded like I had one pissed off bumblebee in the gas tank, and was really noticable from inside the car- even over my exhaust.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Sep 13, 2001 | 12:46 PM
87_Camaro's Avatar
well i have become that my fuel pump is dieing on me, when i make stops on light my car soudns as if it is going to die, then resuems like normal, it has died on me 2 tiems in the 3 months i have had it, i am going ot chage the fuel filter becuas eit looks as if it was never changed, is it expensive to get a new fuel pump???
Old Sep 13, 2001 | 01:42 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The pump's between $60-$100. The labor is what's expensive; unless you do it yourself. The procedure's in the Haynes 82-92 Camaro (or Firebird) manual. It's not "technically" hard; it's just a lot of work. (Trust me; I've done it twice.) But get the f/p gauge!! I got mine for $40 @ Pep Boys. You don't want to change the fuel pump and have the same problem!
Besides, '87Camaro, that sounds like a MAF sensor problem, or a dirty IAC motor (or clogged IAC passageway), or incorrect timing to me.
[edit] Also, if your pump was going, you'd have problems like the car not starting at all, or the car would be impossible to get moving. Kevin's problem sounds more like a fuel pump. (Hopefully it's just clogged injectors, or something else.) But the fuel pressure gauge is great; if I have a bad stalling/starting problem, one of the first things I do (after checking spark) is put the fuel gauge on to make sure I have fuel pressure- when I see that I do, it eliminates the fuel system completely from the problem.
[This message has been edited by TomP (edited September 13, 2001).]
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
