speedo not working and no code
Old Aug 25, 2011 | 04:05 PM
darrell_43748's Avatar
Car: 1992 camaro rs
Engine: 3.1 v6 MFI
Transmission: 5 speed
Axle/Gears: poss rear end
i have a 92 camaro 3.1 v6 mfi 5 speed. my speedo was working. i had to put a fuel pressure regulator on it over the winter. in that time i replaced all dash lights and bypassed the vats with the right resistors. now the speedo don't work and have check engine light and no codes.. need help.. didn't want to replace the vss. as it costs 110.00 for mine. just didn't want to put it on and still not work..any help..
Old Aug 25, 2011 | 04:07 PM
Car: 1992 camaro rs
Engine: 3.1 v6 MFI
Re: speedo not working and no code
i have read alot of threads on here and still stumped.. is there a way to put a test light on the vss plug? or a way to see if its the wire or ground? all gauges work fine..
Old Sep 9, 2011 | 10:23 AM
Car: 1992 camaro rs
Engine: 3.1 v6 MFI
you know never mind on a response.. i will figure it out. thanks for nothing
Old Sep 9, 2011 | 10:41 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
to test the VSS output you need an oscilloscope or a voltmeter.
my guess is that your cluster isn't seated into the plugs all the way, pull it back out and re-check all your work, then clean the contacts.
Old Sep 22, 2011 | 01:02 AM
Car: 1992 camaro rs
Engine: 3.1 v6 MFI
i just bought another cluster it works fine. must have been just the speedo after all thanks..
Jorlain
Aug 24, 2022 05:11 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
