2.8 vacuum hose help!
Old Aug 29, 2011 | 08:02 PM
natalia1531's Avatar
Car: 1992 Camaro RS
Engine: 5.0 V8
I have a 1989 camaro with a 2.8 v6 engine. I recently rebuilt it in the past 2 weeks and there is one last thing I'm having trouble figuring out. in the back/left of the engine, there is a vacuum hose connected near the EGR valve. I have no idea what it connects to (I've looked all around the engine to see if there is something it could go to). can somebody help me figure out where it goes? my car is throwing me a 32 code (egr failure)
thanks.
(picture attached)
Old Aug 31, 2011 | 10:34 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Re: 2.8 vacuum hose help!
I think the is a part mounted to the left(when standing on pass. side facing engine) of the coil on the coil bracket.On the bottom the is a place for a vacume hose.You cant see it very well but can feal it.Look real hard under the coil bracket. I'm still trying to figure my stuff out.There was no motor in it when I got it. Plus I'm putting a 3.1 block with a box of parts that came with the car.
Old Sep 1, 2011 | 12:30 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
I have the same motor, I can try and get picture's, it dark out but I have a flash on camera. See what I can do.
Old Sep 1, 2011 | 12:46 AM
Engine: MPFI
I hope this helps, I have one more to add.
Old Sep 1, 2011 | 12:48 AM
Engine: MPFI
Here is the other one, Like I said it is dark out. If you need more picture's I can get better picture's tomorrow.
Old Sep 1, 2011 | 09:48 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
plug it, will run fine if you can't find a port for it.
it probably ran to the canister.
Old Sep 1, 2011 | 10:30 AM
Car: 1992 Camaro RS
Engine: 5.0 V8
oh wow, thanks for the pictures! they actually helped me alot and don't have to drive an hour away to a junk yard lol
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
usafirebird
Sep 29, 2015 11:58 PM
dusterbd
Sep 29, 2015 08:40 AM
