what is this ?
Old Oct 17, 2001 | 08:54 AM
WaynesRS's Avatar
what is this ?
What is a 2.8 stroker kit ? And what does a 3.4 crank have to do with this ? Dont laugh at my question please lol .Im still learnin. Ya'll are still learnin me
Wayne
Old Oct 17, 2001 | 09:32 AM
87_Camaro's Avatar
i would also like to know what a stroker kit is, please enlighten us
Old Oct 17, 2001 | 09:58 AM
Brian K's Avatar
There is a comapny that sells a couple of kits. One makes your 2.8 a 3.1 adn the other makes it a 3.4. If you bore the cylinders 30 over you make your 2.8 a 2.9 because you increased the cylinder deminsions. Does that help at all..
Old Oct 17, 2001 | 02:58 PM
WaynesRS's Avatar
Ok , Yeah . So its really just another name for boring a block huh ? ..Thanx Brian Wayne ....p.s. ..I did not think a 2.8 could be made into a 3.4 ? ? hmmmm
Old Oct 17, 2001 | 03:11 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I've seen this kit (caint remember the site)
but it is a bored & stroked short block kit. Also caint rememberf the price, but a used 3.4 should be a lot cheaper., but then it it is a used motor.
$150.00 2.8 Auto.
Blown Head Gasket.
turbo has arrived,
working on getting some 3.4 heads.
Old Oct 17, 2001 | 03:43 PM
Camaro_hunter_d's Avatar
The point of a stroker kit is to get more displacement from the motor. You get this by moving the piston up and down more then it usually does. IE 4.3inches UP/Down Movement instead of 3.8 inches
