Timming Question
Old Oct 17, 2001 | 06:50 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Timming Question
Yesterday I hooked up a timming light to my car to see if it was set right, because the has been running rough and I thought it need to be timed. With that said, I took a look at my timming and mark and i noticed that mark was fluxuation up and irraticly between 6° and 8°. I can only supose what the number is do to the fact that i could not read the numbers on the gauge because it was dirty. My question is why was the mark going up and down? My father said that my spark plug wires were shorting out or something. Is this true? I do need to change them.
Thanks,
Robert
P.S. What degree of advance should set my car on?
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
?Flowmaster 80 Series Muffler
?83 Trans Am 15x7 Turbo Fin Wheels
?B.F.Goodrich Radial T/A 225/60-15
?Chevy 2.8L Heddman Headers (Going on soon)
Aol instant messenger: FIREAM
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828
Old Oct 17, 2001 | 07:31 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
10* for automatic while in gear. Replace the wires, it really wouldn;t hurt; unless there less than a year old... then I'm not sure what your problem is
Old Oct 18, 2001 | 02:57 AM
AntiVTEC's Avatar
did u dissconect the EST wire?
Old Oct 18, 2001 | 11:40 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
As far as I know, there's no EST wire on the 82-84 carb'd 2.8's. Are you sure "10 advance" is a spec for an 82-84 2.8? I thought that was just for our multiport injected cars...
If your car still has the original hood, the timing will be on the emissions sticker.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Oct 18, 2001 | 11:11 PM
fiream's Avatar
Engine: 400HP 350
I think the stock advance is 6 or 8 degrees, i'll check in the morning.
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
Old Oct 19, 2001 | 08:46 AM
WideOpenVTwin's Avatar
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
If it is carbed, I don't think it uses an EST, but it should have a vacuume advance that needs to be disconnected and plugged shut.
Old Oct 19, 2001 | 08:53 AM
86Chicken's Avatar
If the timing is fluctuating, doesn't that mean it is tme for a new timing chain (assuming that the timing light is correct)?
Just a thought.
Dale
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
TheExaminer
Aug 19, 2015 10:07 PM
redmaroz
Aug 16, 2015 11:40 PM
