vent hose
Old Oct 29, 2001 | 07:14 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
vent hose
I got a 91 RS with a 3.1. On the passenger side valve cover there is a hose coming from the cover leading into the air intake. I assume this is the crankcase vent hose.It is leaking a little bit and I was wondering what is the cause and the solution.The engine has 46k on it.Replaced the orig with this one.
ken3983
Old Oct 29, 2001 | 08:34 PM
WaynesRS's Avatar
Yeah , you can replace it , or you can just take it out and replace it with a valve cover breather .Just dont foreget to plug the hole thats on the intake pipe ...Wayne
Old Oct 30, 2001 | 09:38 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If you want to get fancy, you could buy some braided hose to get rid of the pipe... but yeah, a small leak = no big deal; the rubber grommet on the valve cover is probably just worn out. I wonder if GM sells a replacement for that!
-Tom P (Hot rodded 1986 Firebird 2.8l)
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
shanelique22
Sep 24, 2015 06:30 PM
