Installing a tach in a car with coil packs???
Old Nov 19, 2001 | 11:56 AM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
No, this isn't third gen, but it IS 60 degree tech I might be buying my '95 GA SE 3.1 back from my sister, and if I do, I want to install a tach in it. Can aftermarket tachs be compatible with the distributorless ignitions found in the 3100 SFI cars? I would like to put an Auto Meter on the dash right next to the driver window like all the little rice boys do
Can this be done? If not, I'm going to get a new IP, either from a junkyard or new at dealer cost through work. The problem with this is that I need to then roll the odometer to match mine...is it hard to do? I don't want to make it less miles, just correct for the car. I wanna see 200k out of this thing if I get it!
Jason E
'89 Camaro RS
-Medium Grey Metallic
-2.8, A4, T-tops, 95k miles
-Hypertech chip, Accel 8.8MM wires and coil
-K&Ns with gutted airbox
-Alpine 60x4 with Boston 746s and RX97s
'97 Z28
-30th Anniversary package (white with orange stripes)
-LT1, M6, t-tops, 46k miles
-Xtant 403a 50x4 + 300x1 powering a 10" Eclipse Aluminum in a JL Stealth box, Boston RM6 fronts, Monsoon rears (temporary!!), Eclipse 5341R CD, All Monster's goodies...
Speed Kills...Wanna live forever? Drive a Ford.
Long Live #3...
Old Nov 19, 2001 | 12:26 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
look in the literature. Go to the autometer sight & see if they have any adptors if neccessary.
Old Nov 19, 2001 | 01:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I don't know too much about DIS, but here's a bit I do know-
There's a crank trigger that tells the DIS unit when to fire. It picks up a signal from a specially designed center "counterweight" on the crankshaft. (This is why '82-86 F-body 2.8's are externally balanced, and why '87-'92 2.8/3.1's are internally balanced- there was no center 2.8 counterweight on the 82-86 crankshafts).
So, I'd imagine you can pick up a tach signal from that crank sensor. You'll find the crank sensor screwed into the engine block...
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 19, 2001 | 04:22 PM
Jason E's Avatar
Thanks for the info guys. Now that I think about it, RKSport sells tachs for Cavaliers, but they want like $250 for a huge Auto Meter...
Anyone have any links for tach makers? Anyone know for sure what can be done? Thanks for the info so far.
Old Nov 20, 2001 | 10:06 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wow, those are some high prices- buy from Summit Racing! Summit Racing wants $185 for that same tach in silver, and $150 for the tach in black.
Oh, and those aren't Cavalier-specific tachometers, either! Look further down on RKSport's "tach page"- you need the "tach adapter" sold below the tachs. So I'd say get your tach from somewhere else, and buy their tach adapter.
Or, even better, go to http://www.autometer.com , and e-mail their tech support about what you want to do. They might offer a much simpler (and cheaper) solution!
I think it's funny how RKSport "only" sells a 5" monster tach; I wonder how many other Cavalier drivers think that's the only tach for their car! That's a hell of a marketing idea! But hell, dude, you could buy a $60 Autometer Street tach and wire it up!
Old Nov 20, 2001 | 01:56 PM
Jason E's Avatar
Agreed That's what I was thinking...getting a regular, decent Auto Meter for like $50-60 and then figuring out how to adapt it...
I'll go to Auto Meter's site tonight...can anyone recommend any other brands besides Auto Meter? How's VDO?
Old Nov 20, 2001 | 04:47 PM
KED85's Avatar
VDO is great, so is Stewart Warner.
I've used both.
Work fine.
So do old tachs from swap meets!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
bryan623
Aug 10, 2015 11:33 AM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
3rdgenparts
Aug 5, 2015 11:57 PM
L98GTA87
Aug 5, 2015 11:02 PM
