Edelbrock Intake with 450 CFM carb
Old Nov 24, 2001 | 11:48 AM
1984Firebird502's Avatar
I just wanted to know what you guys thought about that 60 degree edelbrock V6 intake and the 450 CFM carb. Does anyone know if that will work? I have an 84 2.8 T5 SE. My main concern would be with the computer controls between the carb and distributor. As ALL of you probably know already, I have an s10 carb on mine and it runs crappy because it's not computer controlled. Would this package help? Thanks. I can get these both for $100. Will it be worth it?
1984 Firebird SE
1985 Camaro z28 305 engine T-5 Five Speed Tranny, 92 Camaro Leather Seats Console, carpet everything. Soon to put in 700R4 and 427CI. (Hopefully.
To view my car go to:
http://geocities.com/jmboriss/bluecar.html
Old Nov 24, 2001 | 12:28 PM
bradkeith's Avatar
Boriss, i might be wrong but in 1984, switching from computer carb to non-computer carb doesn't affect the dist? I'm not quite sure on that one.
P.S. did you ever find my house and see my 3rd gens? We ought to meet up sometime.
1986 camaro with 92z28 gound effects, aero wing, 17in American Racing Pythons w/275'40's 4 3/4 Unlimited products cowl, 3.90 auburn gear rear-end with Steve Spohn adj LCA's,Panhard bar. 406 stroked to to 429 motor in the works.
1989 Iroc-z 5.7 white t-tops, 3.42's megashifter, 2 1/2 harwood cowl.
Old Nov 25, 2001 | 02:58 PM
KED85's Avatar
BUY THAT INTAKE SET UP!!!!!
What are you waiting for?????
You can find a distributor ANYTIME!!!!
Get a distb. from a UP TO 1985 S-10 BLAZER, AUTOMATIC!
You are SET!!!!
GREAT ALTERNATIVE!!!!!!
Lucky!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Nov 25, 2001 | 04:10 PM
<font face="Verdana, Arial" size="2">Originally posted by KED85:
You are SET!!!!
Lucky!
</font>
Thanks man, you've been helping me out a lot. So, All I would need is that distributor from an S10? Thanks.
1984 Firebird SE
Old Nov 25, 2001 | 04:34 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Where the heck did you find that setup at????
When I had my 3.4 blazer I would have killed to rip off the tbi and slap a 4bbl on there!!!
SSC
Old Nov 25, 2001 | 07:13 PM
Will this be hard to put on? Will this work with a computer controlled system?
1984 Firebird SE
Old Nov 26, 2001 | 10:49 AM
KED85's Avatar
There aren't any "computers" like on the 1985 F BODY cars & above.
Just get the distb from the Blazer for proper conversion. ONLY UP TO & INCLUDING 1985!! (1986 is TBI)
I have federal cars out in CA, that's why I'm aware of these things.
BUT your car does have some "computer" functions.
When you obtain the carb intake, you'll see differences, but, NOTHING major. That is a "Legal" intake, WITH THE CORRECT 2 BBL. Not Legal with the 4bbl.
SAVE EVERYTHING!!
Chat Soon,
KED85
Karl
Old Nov 26, 2001 | 11:59 AM
Okay, so there are no computers on my 84 between the carb and distributor? So the S10 carb wouldn't matter? Or it would, but it just wouldn't run properly right? Then why is my check engine light always on? Would this 450CFM carb and intake help, or would it just be the same exact problem? Thanks. In Indiana there isn't any emission laws so I'm not worried. THanks man, you're helping me a lot.
1984 Firebird SE
Old Nov 26, 2001 | 02:55 PM
KED85's Avatar
No, I'm not saying that.
You 1984 car, has a computer for "some" emissioins functions.
It's very "slow" compared to current computers. And your current computer "monitors" very few functions, compared to modern cars or even the 1985 MPFI set up.
Your current light is on, as your systems reads a failure in one of the functions.
My 1985 S-10 Blazer, has no computer, all.
NONE.
I'll bet all up & including 1985 2.8 AUTO Blazers (Federal 49 state version, only) are just like my Blazer.
So, by using that specific distributor, you get to remove "some" wires.
Exactly which ones, you'll discover durting your swap.
Needless to say, you have a great alternative.
Go slow, buy the right parts/gaskets ya need, do this swap.
You may be very pleased for your effort & bucks.
You can even get a rebuilt distributor from this place, w/warranty
Norhtern Auto Parts. 800-831-0884.
I DO RECOMMEND you do a new timing chian & new water pump job, now, too.
Those parts will only cost ya about $40+ more and you will have one sweet ride, for under $500, total!!
Rebuild your carb, NOW (the holley), too.
That is the PERFECT carb for that application. That carb goes for about $400, alone.
Good going!
Chat Soon,
KED85
Karl
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
beastin91rs
Oct 9, 2015 07:38 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
