3.73 Gears
Old Dec 2, 2001 | 03:50 PM
PimpRide92's Avatar
3.73 Gears
Anyone have the part # for the richmond gears. i have 3.23's stock now and im not sure on what spline axels i have.
1992 RS 3.1L
Rebuilt Tranny W/
Trans-Go Shift Kit
B&M MegaShifter
B&M Super TransCooler
ES Trans Mount
Dual Snorkel Intake
W/ K&N'S & Custom Ram Air
Flowmaster Exhaust
Accel 300+ Ignition, 8.8mm Wires, Cap/Rotor And Elec. Coil
160* Thermostat
Jet Underdrive Pulley's
1 12" - JL W6 (Loud)
Eclipse 2-Channel Amp
Sony Head Unit
Window Tint 20%
GTS Taillight Blackouts
Red Bowtie Grille
'92 Z28 Wheels W/245-50-16's
Check It Out In The Readers Rides Section Under: PimpRide92
Best Track Time:
1/4 - 17.19 1/8 - 10.88
Spd 1/4 77.19 60' - 2.31
330' - 6.94
Kill's:
80's Stang 4-Cyl, A few Ricers, Ford Tempo(Weak)
'91 OR '92 Z28(Dont Ask Me How) All On A Mesh Up Tranny! 4th Gen 3.4, Cutlas Ciera 3.8,80's V6 Thunderbird,'95 Honda Prelude(2 Fat Guys In It)
'86 IROC-Z 305TPI(My friend said he only had it at 3/4 throttle but he had it pinned and i started pulling in 2nd gear)
Old Dec 2, 2001 | 05:33 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It doesn't matter what spline axles you have; the gearsets don't touch that area. The pinion gear goes right to the driveshaft flange. The ring gear bolts to the differential- and the differential is what takes the axleshafts.
Your '92 would have 28-spline axleshafts, by the way. The gearsets use a 7.5" ring gear. It's basically the same as the early-80's 7 5/8" ring gear; both differential carriers take either size gear, so both sizes are interchangeable. I.e., if you car had a 7 5/8" ring, you could put a 7 1/2" ring gear on it, and vice versa.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Dec 2, 2001 | 06:21 PM
PimpRide92's Avatar
Do you have the part number for the 3.73 gears for my car?
1992 RS 3.1L
Rebuilt Tranny W/
Trans-Go Shift Kit
B&M MegaShifter
ES Trans Mount
Dual Snorkel Intake
Flowmaster Exhaust
160* Thermostat
Sony Head Unit
Window Tint 20%
Red Bowtie Grille
Best Track Time:
330' - 6.94
Kill's:
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
