does anyone make headers for 2.8L??
i think i remember hearing that none or almost none of the V6's have headers available, is this true, or is there someone that makes headers for this engine? if not then is there any porting or anything that u can do to increase flow?
- David
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT
- David
Sure, but not for the fbody platform. At least not currently. I can't help but wonder if you could use S10 2.8L headers or Fiero headers? Even if you could use Fiero headers they're generally cost prohibitive and I know of dyno results showing a hp loss with one unnamed brand of Fiero headers when compared to ported stock Fiero manifolds.
i think i found some for the Blazer\Jimmy at http://www.racesearch.com/CGImp/mhp?man=0 &sort=PRICE&app=0&att=0&sub_cat=0&engtype=8446&year=0&Try+Again=Try+Again&mode=sbpn&cat=2003 being the v6's have so much room under the hood, i bet you might be able to customs fit a y-pipe and cat on them, has anyone here ever tried this??
also, wut kinda gain would someone expect adding a set of headers to a 2.8L? is it worth the money?
- David
[This message has been edited by breathment (edited September 04, 2001).]
- David
Way worth the money in my case. On my 2.8 I had Nitrous ,a cam , a holley tbi, and alot of other small mods before I finally got headers. Really added some power... Worth it.
Ive seen the f body ones come up on ebay before. Used , but hey, keep an eye open.
1992 ext cab S10
173 on NOS, 5153Nos,Black Magic,2030 Crane Cam,11mm Moroso Wires, MSD 6al, MSD Blaster Coil,K&N,Holley Tbi, Edelbrock Headers,40 series Delta Flow,Zexel,Toms 28 spline axles,Hypertech chip, Granetelli 190 lph, Centerforce Dual Friction,Jet pulleys,Spray Bed Liner, Altezzas,Pioneer din 1/2, 01 Vette wheels, Harwood 4 inch hood, and Much more...
1992 ext cab S10
And what are the sizes and dimentions of everything!!! Help us out. Did you use different sized collectors and what not? What are the primaries, how long are they... anything you can provide will help out tremendusly....
1985 Camaro SC - 2.8L, auto.
C'mon, spin 'em for papa...
http://www.xenodrgn.f2s.com/Frontright.jpg
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Here is a post that may help you out... https://www.thirdgen.org/messgboard/...ML/003128.html
Camaro Hunter D is currently working on remaking the headers for the 2.8 he got an orginial set from someone on ebay to use as a guide.
hectre13
Sep 8, 2015 03:38 PM
[For Sale] 1 3/4 budget LS swap headers NEW (CA)
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
