Rocker arms. Again.
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Rocker arms. Again.
I've been looking, but can't seem to find any aluminum full roller 1.6 ratio rocker arms that fit 10mm stud.
Am I just missing them, or do they not exist?
Or, is there a way to get common (cheap-ish) SBC rockers to fit?
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Rocker arms. Again.
someone on here selling crane gold series set for $80, idk the stud size, but i think they are supposed to fit
10mm is 0.393700787 inches. 3/8 is 0.375. So the difference is marginal at 0.018700787. .018 doesn't seem like very much difference. Theoretically they'd probably be fine. That said, the 3.1L heads I had, which had been used with Crane Gold rockers, had aftermarket threaded studs.
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
http://www.summitracing.com/parts/CCA-1414-1/
opps these are just roller tip.. sorry
