3.1 fuel injectors on a 2.8??
Old Nov 18, 2011 | 02:48 PM
FirebirdDude88's Avatar
Car: 88 Firebird formula clone
Engine: Yeah its in there
Transmission: Thats in there too
Axle/Gears: Yeah there in the back
Hey guys, i have a quick question. if i put 3.1 fuel rails, and fuel injectors on my 88 2.8 firebird, would it work? would it give it a little more power? ive been told it would technically make it a 3.1 motor.
Old Nov 18, 2011 | 06:51 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: 3.1 fuel injectors on a 2.8??
Lol....they should work, but the most that will change is that you will probably run rich.
Old Nov 18, 2011 | 10:15 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Nov 19, 2011 | 05:16 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Same fuel injectors were used for a couple years on both engines... You'll be fine, provided you match the full set and don't mix them.
And no, don't swap the fuel rail. The ECM won't be happy and will have difficulty starting in the colder weather. And no, the only way to make a 2.8 into a 3.1 is to put in the 3.1 rotating assembly in the lower end of the engine.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
