tune up
Old Nov 19, 2011 | 01:46 PM
emerald91fbird's Avatar
Car: 1991 firebird
Engine: 3.1 l v6 mpi
Transmission: auto
tune up
hey im switching out plug wires from crap 7mm wires to taylor street thunder plug wires and im looking at these coils
http://www.amazon.com/ACCEL-140011-R...ar=1&carId=001
http://www.amazon.com/MSD-Ignition-8...731419&sr=1-12
http://www.taylorvertex.com/Products...ting?id=220694
any ideas on a cap and rotor also i need plugs
Old Nov 19, 2011 | 05:14 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: tune up
DO NOT BUY THE $50 ACCEL PAPERWEIGHT COIL... Enough said.
Any cap and rotor would be fine (there really isn't much in the way of choices). The MSD Blaster coil is actually the coil recommended by the people who designed our ignition systems, and get whatever coil you get as far away from the exhaust as the wiring will allow.
Old Nov 19, 2011 | 07:20 PM
Car: 1991 firebird
Transmission: auto
Re: tune up
ok im leaning towards taylor's coil and cap and rotor not bad price but whats plugs should i run and i moved the coil up on the bracket when i got the car
Old Nov 19, 2011 | 08:00 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: tune up
Factory plugs are Delco R43TSK's... Replace them with the same as you can't do any better and only worse.
When I said to get the coil away from the exhaust, I meant off of the bracket, period. The bracket is bolted to the exhaust port portion of the cylinder head, which gets hot. The cooler you can keep the coil the longer it will last.
Zell1luk
Sep 29, 2015 10:36 AM
