1985 v6 2.8 poor mpg
Old Nov 14, 2011 | 10:43 AM
redneckcamaro's Avatar
Car: 1985 sport coupe
Engine: was 2.8 now 3.4
Transmission: 700r4 auto
My 85 2.8, 700R4has two problems that i can’t figure out
  1. Poor gas mileage
· it is getting approx. 15-19 mpg
  1. High RPM when warm
· Normal idle while cold in park
· High idle when warmed up 2-3k RPM in park
It will stumble and/or bog down when the throttle is opened quickly. I have cleaned the throttle body and the IAC valve. I recently replaced the coil, wire and sparkplugs. I have also cleaned the injectors. Recent fuel filter and fuel pump.
Please help any advice is appreciated
Old Nov 14, 2011 | 06:46 PM
ex-x-fire's Avatar
Re: 1985 v6 2.8 poor mpg
Does it get up to operating temp?
If it does, you need to do a coolant temp sensor resistence test at different temps. You need a ohm meter, thermometer, & a pot of water. test the sensor at different temps, google "GM coolant temp sensor resistence" for the temp/ohm values.
When the engine is cold, the temp sensor should be close to outside temp. If you know anyone w/ a scanner it'll be easier to test the sensor.
Old Nov 15, 2011 | 09:55 AM
Thanks for the advice, are you talking about a code scanner?
Old Nov 15, 2011 | 12:34 PM
ex-x-fire's Avatar
If the code scanner can read live data, the it'll help you check the cts.
Old Nov 19, 2011 | 06:13 AM
Friguy's Avatar
Car: 1989 Pontiac Firebird
Engine: Multiport 2.8L V6
Transmission: 700r4 with Shiftkit
Axle/Gears: All Stock
what would the max mpg for city and hwy be for the 2.8 anyways?
Old Nov 20, 2011 | 08:06 AM
my mom had a 87 ttop 2.8 and it would get 28mpg. When my dad would drive it to work in kernersville which is a 30mi drive apx. he would get 25-26mpg.
snakeshooter
Sep 7, 2015 11:13 AM
auxout
Jun 14, 2001 01:11 AM
auxout
Jun 12, 2001 09:35 AM
auxout
May 4, 2001 04:48 PM
