more power out of a 85 2.8 700r4? WHAT CAN I DO?
Car: 1985 sport coupe
Engine: was 2.8 now 3.4
Transmission: 700r4 auto
I am looking for more power/better response out of a 2.8.some mods i was pondering and reading on are
- better heads or aluminum heads
- diferent plentums/better flow
- mabye opening up the TB more
any help is appriciated
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: more power out of a 85 2.8 700r4? WHAT CAN I DO?
Do a 3.4 swap
Delta cam regrind is not too expensive
Read this
https://www.thirdgen.org/forums/v6/5...ost-power.html
and this
https://www.thirdgen.org/forums/v6/3...arts-60-a.html
and all the other stickies at the top of the page.
Read this
and this
Car: 1984 Pontiac Firebird
Engine: 4th Gen 3.4 V6
Axle/Gears: Stock
^ This. Go to the junkyard and find you a 93-95 Camara with a good 3.4 cheap and swap it in.
is the 3.4 swap a plug and play mod or will i kneed a new wire harness and computer ex.
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
It's a plug and play engine. You have to swap over your intake though
so the what about the computer? are they obd2? or the same obd1?
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
step 1: do search
step 2: read
step 3: read more
step 4: begin engine modding
seriously though all the info is in the links at the top of the v6 forum
step 2: read
step 3: read more
why would you bother swapping a v6? if you look around you could find an 8 for cheap. My brother bought his entire iroc with a 305 for 100 bucks.
there are many guys on here that have v8s for cheap. I have a spare 305 block if you want it.
In the long run, the swap even for another 6 sounds expensive.
I would think your better off getting a 305 auto in one shot for a few hundred and swapping that.
And you clearly haven't done the steps above...
and different front springs
me and my dad were working on resolving the engine idle problem i had and as we were looking around we found a cam position sensor, so i already have a 3.4 and didnt know it.
now that the idle problem i had is resolved we were able to advance the timeing 5 degres...it runs like a diferent car
Does it have the 2.8L EFI system?
yup! and it does still have the 2.8 EFI, i do have anouthere que tho why doesent it have a syrpintine belt???
Car: 1984 Chevrolet Camaro
Engine: 2.8L Carb V6 for now
Transmission: 1 speed 700r4 for now
Axle/Gears: 3.42 for now.
How did you figure out it was a 3.4 again?
Iroc8t8
May 4, 2026 08:09 PM
someone972
Aug 30, 2015 12:52 AM
sailtexas186548
Aug 24, 2015 10:11 PM
lots of info on here about the 3.4 swap..
