fuel injectors
Old Dec 5, 2011 | 01:24 PM
jiyasa's Avatar
fuel injectors
I'm going to replace my injectors soon and since I've never attempted this before, is there anything else I need to buy to do the job? Is there a sticky or previous thread on here on how to accomplish this? I would greatly appreicate it, thanks
Old Dec 5, 2011 | 01:47 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: fuel injectors
It's not difficult and you don't need any special tools. You just need to be careful, methodical and keep everything clean. You should have a manual but it's pretty clear what you have to remove to get to the injectors. There are threads with more details though.
Old Dec 5, 2011 | 02:00 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: fuel injectors
It was surprisingly easy the first time I did it. Isn't that just like a guy to say, LOL! Seriously, pull the top plenum; 4 bolts I think to hold on the fuel rail; remove the plugs on the injectors and remove them from the fuel rail. Reverse order to reinstall.
Watch you that you don't rip the o-rings fitting them into the fuel rail and then the manifold- this is easy to do, particularly on the fuel rail, as the edges are sharp. Bad o-ring on the manifold means vacuum leak and smog/tuning issues; bad o-ring in the fuel rail means fuel leak and fire! Rub some vasaline on the o-rings and go carefully... GOOD LUCK!
Old Dec 5, 2011 | 02:40 PM
jiyasa's Avatar
Re: fuel injectors
Okay, sounds easy enough. Thanks guys, I appreciate it.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
