o2 wire length?
Old Feb 6, 2012 | 06:21 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
o2 wire length?
Anybody know the total length from sensor to ECM? Or better yet, length from sensor to plug?
Installing a heated o2 and re-doing the connector. My current wire setup probably isn't even the right length, and I don't have an original single wire o2 to look at.
Old Feb 6, 2012 | 06:48 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: o2 wire length?
The sensor to the plug is not far as I just lengthed mine the other day. Maby 18 inches in total. Id go look if you really need the exact look... Its frezzing outside!
Old Feb 6, 2012 | 06:58 PM
Engine: 3.4
Re: o2 wire length?
No need. Looks like they vary a little depending on manufacturer once I found some listing online. I found two of my old sensors, and there's about an inch difference (bosch and delco). I remember the stock replacement single wire o2's barely reaching because of sensor placement with the headers, so I'll try to get this about the same, but with a tad of slack.
Hopefully an extra inch won't screw up the reading too much.
Old Feb 6, 2012 | 07:08 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: o2 wire length?
Yea the stock wire is definitly a tight one... I guess GM figured out that length perfect..and save on cash..
Old Feb 6, 2012 | 07:18 PM
project89's Avatar
Re: o2 wire length?
the lenght of the wire wont screw with the reading if u have to add wire solder it dont use crimp conectors
Old Feb 6, 2012 | 08:42 PM
Engine: 3.4
Re: o2 wire length?
Stuck now until tomorrow anyway. I'm trying to use a GM 4wire plug that came with the o2 I'm installing, and pulled the other half of the plug off a truck at the junkyard.
Pulled the signal wire connector out of the plug, wrecking the lock tab, but figuring the plastic lock would keep it in, and I'd just solder the harness wire right onto the crimp.
I cut the stock plug off. Anyway, it's just not possible to secure the connector to the wire and get a decent solder where it's at (if I don't drip solder onto my face).
Hopefully I can find another connector at the big electronics specialty store tomorrow, crimp it onto the bare wire enough to hold it, and them maybe I'll be able to solder it easier and insert it back into the new plug.
I'll try soldering it from above first once it's crimped, but there's just too much crap in the way up there too, and it's impossible to peel it back from the harness.
will check the fuel pressure, timing, and replace the fuel filter tomorrow too. Hesitates a bit when accelerating, is gutless, and mileage is dropping.
BRoss99
Aug 10, 2025 05:08 PM
midge54
Dec 27, 2019 04:14 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
