Why would a single cylinder periodically fail to fire?
Old Mar 4, 2012 | 12:56 PM
Blaze of Glory's Avatar
Car: 92 Firebird
Engine: 3.1L V6
My car's been running rough. I finally found a big clue.
My number 5 cylinder fails to fire sometimes. Using a timing light, I was able to see that there is no spark whenever the car starts hesitating. I checked all the other cylinders and they all seem fine. I tried swapping the wires and the spark plugs and the problem didn't change. The cap and rotor appear to be in good shape.
If the problem was random among all the cylinders I might think it was the ignition coil, pickup coil, or the ICM... but just one cylinder? I mean it seems like it fire ~75% of the time....
So now I'm scratching my head. What could cause just once cylinder not to fire sometimes???
Old Mar 4, 2012 | 02:04 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Why would a single cylinder periodically fail to fire?
I take it the plugs are good too? Gaped good and not black. Should be a nice tan color.
When does it do that..at idle, under acceleration??
Old Mar 4, 2012 | 05:37 PM
ex-x-fire's Avatar
Check the distributor for looseness, sometimes that happens after alot of mileage. Remove cap & try to wiggle the rotor, it'll wobble alittle if its loose.
While you have the cap off look for arc trails or carbon tracks. Might be a defective cap & rotor.
Old Mar 14, 2012 | 12:19 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
My bet is on cap, its the only thing other than plugs and wires that can be specific to just 1 cylinder.
Old Mar 14, 2012 | 01:39 AM
Car: 92 Firebird
Engine: 3.1L V6
I guess I'll never know for sure... I ended up replacing the whole distributor, including the cap. My car runs okay now.
Old Mar 14, 2012 | 06:05 AM
Engine: 3.8, 3.4
The only thing that can really go bad in the dizzy itself is the pickup coil, and its connections can corrode, but since the dizzy fires all 6 cylinders without using cylinder specific ones, I can assure with pretty good certainty it was the cap, but probably didn't hurt to replace the dizzy considering the age of it.
Old Mar 14, 2012 | 06:15 AM
ex-x-fire's Avatar
The bearings can go bad causing a wobble, not common, but its a place to look at on a high mileage engine.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
ericjon262
Sep 11, 2015 06:07 PM
