Now its leaking coolant!
Old Mar 22, 2012 | 12:32 PM
SylusMk2's Avatar
Car: 83 Berlinetta
Engine: 2.8
my 91 3.1 RS
its leaking coolant out of the water outlet on the top of the engine.....you can see it slightly dripping while its at idle but when you rev it it pours out.....
i replaced the top radiador hose but thats obviously not the problem....is it the water outlet itsself? and exactly hos is the hose supposed to be hooked up? there is a little stopper thing on the neck is that right?
Old Mar 22, 2012 | 01:40 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Now its leaking coolant!
Originally Posted by SylusMk2
my 91 3.1 RS
Sounds like it is the port for the heater hose. If so there is a repair kit for it. GM has them (or used to). I've also seen that same kit on the Help Rack. Consists of a new metal fitting, clip and o-ring.
RBob.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
aaron7
Sep 30, 2015 09:15 AM
