1984 camaro carb linkage HELP!!!!
Old Mar 25, 2012 | 07:29 PM
joeallen1984's Avatar
ok ya'll i got a 1984 Camaro 2.8L 2 barrel i had to remove my factory carb to replace the fuel line and the linkage popped off of it and now i cant figure out how to hook the linkage or vac lines back up. can anyone help me out here? i looked in my haines manual and its not very clear as to where things hook up at if anyone could possibly post pictures of their linkage/vac lines and where they run to i would appreciate it SOMEONE PLEASE HELP!!!!
Old Mar 27, 2012 | 04:39 PM
19camaro83's Avatar
Car: 1983 camaro sport coupe
Engine: 2.8l v6 - stock motor
Transmission: NWC t-5
Axle/Gears: whatever came stock (?)
Re: 1984 camaro carb linkage HELP!!!!
The linkage is on the passenger side, and it hooks into the hole with a bushing on the bracket, via a clip. Very simply, actually. Vac lines aren't too bad either, I can try to snap a picture after work, but chances are it will be too dark to get a good picture.
Did you take the carburetor completely off of the engine? Or did you just loosen the nuts off the studs and flop it over?
Old Mar 27, 2012 | 05:15 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
go to a s10 site, 99.999% of member here have fuel injection.
they had the same carb'ed v6 allot longer.
Old Mar 27, 2012 | 05:18 PM
19camaro83's Avatar
I just got done dicking with mine today, so it is still pretty fresh in my mind. If he removed the carburetor from the engine he should have marked his vac lines as he removed them. Makes things a whole lot simpler. I don't understand why he took the carb off in the first place, the fuel line is at the rear of the carb (strange!), but you can get to it pretty easily from the driver's side with a 1/2" flare wrench.
Old Mar 28, 2012 | 12:25 PM
yea i shoulda marked the vac lines lesson learned lol the more i mess with this engine the more im starting to think its not the original motor cause the fuel filter houseing nut was on the back drivers side of the carb instead of being in the front center where it shoulda been at. the fuel filter houseing nut was all rounded off to hell and when i was able to get a wrench to grip on it it just twisted the hell outa my fuel line which kinked it so i had to remove the carb to get the fuel filter houseing off AND the put a new fuel line on seeing as how the one that was on there ran under the carb.
Old Mar 28, 2012 | 12:28 PM
i took the carb completely off. as usually happens to me with my cars i start working on one thing and something else gets messed up i was just trying to change out my fuel filter but the houseing nut got all rounded off and fuel line got kinked so i had to completely remove the carb to get to the fuel line. i would appreciate it if u could snap a picture for me of it. THANKS!!!
Old Mar 28, 2012 | 01:17 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
here are pics of my S15 before I took it apart, big pics so I could figure it out later. similar to what your taling about. fuel line in the back. [don't know anything about em yet, took pics, removed top end, far as it got]
IM over quota for the month so Im being throttled speed wise, gonna take like an hr to finish uploading them. 15 pics
http://xvnetwork.com/S15/
Old Mar 29, 2012 | 09:22 PM
19camaro83's Avatar
That fuel line is supposed to be in the rear of the carb on the driver's side, at least that is where mine is. I know it's pretty weird, I have always seen fuel lines in the front of the carbs. I'm not gonna lie, I completely forgot to get a picture for you after work that night. I will be under the hood of my car again soon (hopefully tomorrow) as I have to replace the mixture control solenoid. DO NOT BREAK THAT THING! So when I am under the hood I will get a picture of it all back together for ya.
84z96L31vortec
Aug 20, 2017 12:16 AM
chevyguy1999
Aug 16, 2015 08:49 PM
GVMV
Aug 16, 2015 08:01 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
