why does my car run better with the idle air contol valve unpluged
Old Apr 16, 2012 | 05:43 PM
schlegel94's Avatar
Car: 89 s10 89 firebird
Engine: s10 has 4.3 firebird has 2.8
it will stall out and miss a ton with it pluged in but only miss a few times and not stall out if not pluged in the iac is new and all
Old Apr 16, 2012 | 07:30 PM
schlegel94's Avatar
Re: why does my car run better with the idle air contol valve unpluged
please anyone its my daily driver
Old Apr 17, 2012 | 12:02 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Did you do the idle learn procedure? And did you make sure to set the initial pintle position correctly? Start the car and let it idle for a while then shut it of and start again. Cars can be different. Mine started and idled first time with a new iac. If it doesn't work you may have other issues.
Old Apr 17, 2012 | 09:07 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
more info pleas im doing the iac
specialized
Jun 18, 2022 09:26 AM
86IROC112
Aug 17, 2015 02:00 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
