compression hieghts of 2.8 and 3.1 pistons
Old Apr 25, 2012 | 08:51 PM
project89's Avatar
anyoen know the compression hieghts of the 2.8 and 3.1 pistons
i dont have the info off hand and i need it
Old Apr 25, 2012 | 09:00 PM
project89's Avatar
Re: compression hieghts of 2.8 and 3.1 pistons
trying to figure out if a 2.8 crank with a 6inch rod and 3.1 piston will come close to working
a 6 inch rod 2.8 with a turbo, or high compression hyrbid would be a pretty nasty build
Old May 7, 2012 | 11:27 AM
firstfirebird's Avatar
The difference in crank throw is .3", divide that by 2 and that's what you get for your pin height difference between the 3.1 and 2.8 (.150"). If you put a 6" rod on a 2.8 crank and 3.1 piston, your piston will be proud .140" out of the block (3.1 pistons are .010" in the hole, 2.8 are zero deck).
Old May 7, 2012 | 02:57 PM
project89's Avatar
dammit and the 3.1 pistons cant be flycut enough, forgot about halving the crank throw distance
Old May 15, 2012 | 08:08 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
60*v6 has a CR calculator on their site fyi, useful for figuring out that kinda stuff. Also if you just run 3x00 heads on a stock 2.8 it puts you at a pretty damn high CR from what I recall when I did the calcs on it.
FormulasOnly
Jul 23, 2018 08:47 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
usafirebird
Sep 29, 2015 11:58 PM
