anyone know what this guy is talking about?
Old May 24, 2012 | 02:49 PM
Camaro25thaniv's Avatar
Car: 1992 Camaro Rs 25th Aniversary
Engine: 3.1l
this guy came and bought my monte carlo and we got talking about my camaro sitting next to it. i told him the fuel pump isnt turning on when i turn the key over and the fuel pump, relay, and fuses have been checked\replaced. he asked if i had a chip in my key. i looked and did. he said that it was a theft thing and sometimes the tilt steering can loosen some wires or something and cause the car not to start. fuel pump not turning on be one of the things it does. has anyone ever heard of this? he really didnt explain much and i have no idea what wires to check.
Old May 24, 2012 | 03:05 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: anyone know what this guy is talking about?
not positive, but im pretty sure the fuel pump does kick on and prime. VATS disables cranking and injector pulse. everything else i believe works
Old May 24, 2012 | 03:12 PM
project89's Avatar
correct vats does not diable the fuel pump
make sure ur fuel pump is getting power with the key on and while cranking the engine
fold down the rear seat and pull up the carpet off the hump behind the seat
once u do that u will see a 3 wire connector, disconect it and probe the leads with a test light while osmone cranks the motor over if u get no power then either the relay is bad or the fuse is bad or u have a break in the power wire somewhere
if u do get power back there the fuel pump is bad
Old May 25, 2012 | 11:31 AM
Engine: 3.1l
im getting power back there and tested pump. pump turns on as it should. idk
Old May 25, 2012 | 11:58 AM
Engine: 383 hsr
does your engine even crank over?
Old May 25, 2012 | 12:34 PM
Engine: 3.1l
yup. acts as it should just doesnt start because the fuel pump isnt kicking on.
Old May 25, 2012 | 03:14 PM
Engine: 383 hsr
wait,,you just said you tested the pump and its working as it should..... so which is it, does it or does it not work? toss a fuel pressure guage on there and tell me what it sais
Old May 25, 2012 | 07:05 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Check for codes... You may either have a code 46 (VATS, disables the fuel injectors, NOT the fuel pump) or a code 54 (fuel pump circuit fault). If the pump is receiving power but not running, it's probably the pump... Check the fuel pressure, as was said above, after checking for codes.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
mustangman65_79
Aug 13, 2015 07:36 AM
