Rear Power steering pump
Old Jun 16, 2012 | 02:44 AM
crazybird's Avatar
Car: 1987 firebird
I have a 2.8 and i removed my ac. the rear bracket doesnt fit. but i cant find a non ac bracket??????
Old Jun 27, 2012 | 08:57 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
Re: Rear Power steering pump
I asked the same question...you simply dont use it. Get a steel bolt and push the power steering bracket up to the second hole. There is two holes next to each other (the ones that bolt to the cylinder head) use the hole on the right. Then install the belt using the non-a/c diagram. Unless you can find a non-a/c in your junkyard.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
