what the hell just happened?
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
I was driving on the highway at about 80-85 mph when the ses light pops on and the gas guage dives from 1/2 to 1/8 tank.
I pulled into autozone parking lot to pull codes, nothing.
new plugs, wires, cap, rotor, ignition control module, all new vacuum lines, new brake booster, new y-pipe back exhaust. When I started the car up from Autozone, the car bogged, sputtered, then died. I ended up pushing it a block to a gas station about a block away. It only took 7 gals.
Then started right up. What the hell?
Re: what the hell just happened?
When you mention the fuel gauge dropping like that , It leads me to wonder if something put a massive electrical drain on the circuit , as in something shorted out , and then took out a fuse that may have left some engine system or another not functioning . I don't know of any connection between the fuel gauge and the ECM , so whatever the problem is it's gotta be fairly big to affect both .
As a little electrical side story , , , when I bought my car , at random different sensors would trip trouble codes that mostly wouldn't come back once reset . It finally got bad enough for a look around to find the problem , and what a problem it was ! The rearmost bolt on the exhaust manifold had fallen out (as seems common with our 6 cyl engines) and was allowing hot exhaust to blow right onto the wiring harness that was nearby ! All kinds of wires were melted together , and I'm amazed that it ran at all !
A rewire was done , as well as the missing exhaust bolt taken care of , and no more weird electrical gremlins have been observed .
Have you checked your harnesses , especially the underhood ones , for problems like this ;
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Is the check engine light on and you not pulling codes? You said it was on but you got no codes at AZ?
Car: check
Engine: check
Transmission: check
The fuel in the gas tank was boiling. Caused a lack of fuel pressure and the gauge float to drop. Adding fuel to the tank cooled it to stop it from boiling. There is a long thread about this issue on the TPI board here.
RBob.
RBob.
Thanks for all the replies.
Missing a few exhaust studs ( po snapped the heads off flush with manifold) wiring looks fine.
the boiling gas sounds like what it was but the muffler to tank heat shield is in place ( trust me working on the muffler I hit it with my wrist, 3 stitches later ……)
How would I check and cure the boiling gas?
Car: check
Engine: check
Transmission: check
As for the boiling fuel, some advocate adding, IIRC, diesel fuel to the tank. Just a 1/2 quart? Here is the thread:
https://www.thirdgen.org/forums/tpi/...regarding.html
Other then the diesel (kerosene maybe? It is in that thread), no one has been able to fix the issue.
RBob.
