Vacuum lines on top of the Throttle body....?
Old Jul 16, 2012 | 09:11 PM
crazybird's Avatar
Car: 1987 firebird
What these two vac lines for? the one on the right (facing rear) has been long gone. Do I need to plug the hole? I know that the answer is here somewhere. I looked and looked. I just need it explained in very simple English what these two lines do. And if they are necessary.
Old Jul 17, 2012 | 03:51 PM
crazybird's Avatar
Car: 1987 firebird
Re: Vacuum lines on top of the Throttle body....?
Ok so I figured out that the left hose goes to the fuel pressure reg. That one is in good shape. I want to just plug the hole on the right. EGR and PUrge have long been gone. So can I just plug the hole?
Old Jul 17, 2012 | 04:38 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Will bump for you
Old Jul 17, 2012 | 05:23 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Short answer is YES. Long answer is that, unless you want that hole sucking in umetered/unmeasured air every time you open the throttle (because it's a ported vacuum source in front of the throttle plate), you will want to plug it.
And for future reference, those 2 ports are reversed on the 3.1 TB...
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
apie2546
Aug 10, 2015 05:43 PM
