1992 RS 3.1l Serpintine installation
Old Aug 10, 2012 | 07:05 PM
pirishmen0369's Avatar
My 3.1l recently threw the belt off in the night and the previous owner had removed the smog assembly i believe so i was wondering what size belt i would need to fit w/o the smog pump and if anyone had a diagram available? as i have the Haynes manual and the only thing it says is refer to diagram on vehicle.
Old Aug 10, 2012 | 07:18 PM
project89's Avatar
Re: 1992 RS 3.1l Serpintine installation
u need to take a string and wrap it wround the pulleys and then measure it
Old Aug 11, 2012 | 07:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
With no pump and with A/C, this is the belt:
K060915, that is a Gates Micro-V belt number.
It is a good idea to get an idler in place of the smog pump. As when running the A/C the belt will flop around a lot. This thread has info on that along with pictures of the routing. The belt routing is the same with or without the idler.
https://www.thirdgen.org/forums/v6/6...ll-have-c.html
RBob.
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
