how do they do it???
Old Aug 14, 2012 | 03:26 PM
thatoneguy5x's Avatar
Car: camaro
Engine: 3.1
Transmission: auto
i keep reading posts about people getting like 27 mpg when i barely get 15 out of my 3.1, what do i need to be up in that range? most recently ive been getting about 9 mpg city. its getting expensive especially cause gas is at $4.15 a gallon. ive already changed plugs and wireswhats next??
Old Aug 14, 2012 | 04:12 PM
Car: camaro
Engine: 3.1
Transmission: auto
Re: how do they do it???
could a leaking pcv valve cause poor mpg's
Old Aug 14, 2012 | 04:54 PM
yendor's Avatar
https://www.thirdgen.org/forums/v6/6...or-tuneup.html
take a peek here, its not unusual to get 25+ with a 3.1. Heck, when I got my car I drove it 1300 miles home and I thought the fuel gauge was busted. There was no way I was averaging 25 mpg, but I was.
Old Aug 14, 2012 | 05:40 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Christ man, I get better MPGs out of my car and its turboed. You need read through that link above and tune her up. Your car should pull 25 or so on the highway but a 15-20 in town depending on your habbits. At least thats what mine always did stock and it was in good shape and a automatic.
Old Aug 14, 2012 | 05:51 PM
b_the_j's Avatar
Car: 92 RS
You most likely have a brake caliper dragging. A weak fuel pump can affect this as well.
Old Aug 14, 2012 | 06:16 PM
fasteddi's Avatar
Car: 1991 Camaro RS
There's a ton of things, O2 sensor, fueling issues, spark/timing issues, or some mechanical faults. We as listeners can not pinpoint the problem by just hearing that bad MPG's are the effect
Start with a tune up and assure that the engine is is in good running shape.
Old Aug 14, 2012 | 06:32 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Old Aug 14, 2012 | 10:39 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Originally Posted by Edwardgp
Agreed
I get mid 30's hwy with mine but closer to 10 in the city
Old Aug 14, 2012 | 10:43 PM
Car: camaro
Engine: 3.1
Transmission: auto
thanks for the replies sadly i dont have alot of money to do it all, already did the O2 and just got the pcv and gromet thats happening tomorrow. im trying to do the least expensive first. how do you fix a dragging caliper?? i feel it drag sometimes when i first start her up but after a minute or 2 i cant feel it
Old Aug 14, 2012 | 10:52 PM
Cat Amanigh's Avatar
Car: 91 RS
Engine: 305 topped w/ Summit Holley Clone
Transmission: 700R4, a placeholder for that T-56
Axle/Gears: 7 5/8, 2.73
Usually caliper drag can be fixed by replacing the pins on the offending caliper and applying a generous amount of grease to ensure it doesn't hang up again. It's possible that the rubber seal on the piston is weakened and not pulling the pad back as far as it should, also, but far less likely in my experience.
Also, if that's the issue, you'll want to replace your brake pads at this time, and ensure that ALL your caliper pins are properly greased.
Old Aug 15, 2012 | 02:57 AM
Car: camaro
Engine: 3.1
Transmission: auto
ok ill do a bit more research on it and go from there thanks for the info
