Serpentine Belt Question
Old Aug 27, 2012 | 06:18 AM
ricklee4570's Avatar
92 Firebird, 3.1 V-6. The AC compressor pulley bearing went out. It literally seized up on me on the highway. I limped in to an Advance Auto and bought a belt for a non AC 3.1 and bypassed the seized up pulley.
Where the belt goes from the power steering pulley to the belt tensioner pulley there is about a papers width of clearance where the top of the belt from the water pump is running, In other words the belt is almost rubbing against itself where it comes back the other way.
I installed a 1/2 inch shorter belt, and that has helped, but with any stretch or wear on the belt and they will be rubbing against each other.
Any suggestions?
Old Aug 29, 2012 | 07:44 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Serpentine Belt Question
Don't worrie about the clearence issues. It's normal mine has been like that for a good 5 years.
Old Aug 29, 2012 | 08:13 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Old Aug 29, 2012 | 09:41 PM
project89's Avatar
the power steering pump has 2 mounting locations on some cars/ look at the top bolt hole u may be able to remove the bolt and slide the bracket to the rleft which will raise the ps pump pulley up a lil which will give more clearance were the belt passes the water pump
Old Aug 30, 2012 | 08:18 AM
Thanks, I will check the power steering pump. I only have about 1/8 inch of clearance now.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
mustangdmurder
Aug 21, 2015 07:17 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
