torque converter stall need help
Old Oct 1, 2012 | 12:17 PM
ice_man0617's Avatar
Car: 89 Camaro RS
Engine: 3.2L V6
Transmission: 700R4 mega monster
Axle/Gears: Auburn LSD/3.73 Richmonds
Ok first things first i have a 89 2.8 rebuilt trans but i have the wrong stall i was given a 3k and i need to seriously go down becuz we all know thats to high even for the tpi's. I need to know if a 2350 is ok or should i go lower and if so where to get it from and how much
Old Oct 9, 2012 | 05:15 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: torque converter stall need help
Anything done to the motor? 3k isn't necessarily too high (deff not for a TPI car), it just depends on what done to the car. If its stock, yes, I agree you should go smaller. the 2350 should be fine. That's about what mine is and on the street you can't even tell that its a "high stall".
Old Oct 10, 2012 | 04:33 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I cant remember what stock is but its somwhere arround 1750-2k stall. I have a 2800Rpm advertised stall on my car. I could tell the difference arround town a little. I would just have to push the gas a little more to move but it wasent too bad. Without a camed or modded car I would stay with the lower stall. But if its already in the car then why take it out?? Slap a Delta 260 grind cam in if you can(they cost 120 bucks shipped) and have fun with it IMO> The main reason youd want a cammed car or a modded one for using a higher stall is because youd want to shift your power range up a tad to match the stall converter.
What kind of converter did you get and where did you get it if you done mind me asking. Is it a GM61HD converter???? Because thats the only higher stall I could find for our narrow 700r's.
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
rjcme
Sep 5, 2015 01:23 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
