which injectors should i use?
Old Oct 6, 2012 | 06:59 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I got a set that test at 16.2 on all 6 that are out of a 2.8 set up. a set out of a 3.1 that all test at 12.3 and a set off a 3.4 engine that reads 12.3 on all 6.the opening in the end of the 3.4 ijectors is bigger than the 2.8 or 3.1.I have no idea what brands they are or any of that.I just know they where all working ing there respective cars
Old Oct 20, 2012 | 12:20 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: which injectors should i use?
The first set is the only one that is flowing as much as it should be, use the 2.8 ones that are flowing 16.2, the others are not flowing as much as they should be, from what I recall stock was 16 or 17 for 2.8 injectors, and obviously a 3.1 and 3.4 should be higher, I think 19 lbs for 3.4l.
Old Oct 21, 2012 | 05:55 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Wrong.
He's talking resistance measurements. Anything above 11.8 ohms is acceptable, anything less automatically goes in the round file.
Again, as I've posted numerous times before:
2.8 injectors and 3.1 injectors: 15.4 lb/hr flow rate. May also be 14.7 depending on which injectors are installed.
3.4 injectors: 18.4 lbs/hr flow rate. Same as the 3100 (small port).
http://users.erols.com/srweiss/tableifc.htm
DO NOT use the 3.4 injectors on a 2.8. I made that mistake and only got rid of the code 45 (rich exhaust) by swapping to a full set of 84888s.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
