V6 Power Steering Pump Bracket search
Old Oct 12, 2012 | 06:29 PM
thunder69n's Avatar
Car: 87 Firebird Auto V6 2.8l
I am looking for a V6 Power Steering Pump Mounting Bracket.
The front Aluminum one broke on my daily driver. I had previously removed the rear steel brace :/
Fits on my 87 firebird V6. My Ac and Power steering pump mount to this bracket.
Part number I have seen for the attached picture
old gm 14102535 part number changed in 1990 to 10137045
Attachments: File comment: picture of bracket needed.
Old Oct 12, 2012 | 06:31 PM
thunder69n's Avatar
Re: V6 Power Steering Pump Bracket search
House of Camero was not able to find another one with my description.
I don't see V6 option from like Hawks, Summit racing, Classic Industry's.
Called Local GM Dealer, Parts section confirmed part numbers and numbers change listed for V6 2.8l, But showing no warehouses with stock left on deleted part.
Old Oct 12, 2012 | 08:19 PM
project89's Avatar
best bet is junkyard
Old Oct 12, 2012 | 10:04 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
There is one on ebay for like $69 with the pump..there is usually one posted every other week or so on ebay.
Mine broke as well, went to a guy locally and bought one for $20 bucks. $69 isn't bad for both the pump and bracket.
Old Oct 13, 2012 | 07:45 AM
ex-x-fire's Avatar
Why did you remove the rear brace?
Old Oct 13, 2012 | 08:35 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
If you cant find one off of ebay let me know as i have one. But to ship it to you would be 15 bucks by itself
Old Oct 14, 2012 | 01:18 PM
thunder69n's Avatar
Thanks everyone, I ended up finding one through
www.RearCounter.com
Need to set up my Paypal, I have not been able to shop Ebay in a while.
I changed Headers at one point,
I may not have the original lower stud bolt that brace attached to headers.
I ended up removing rear Power steering to manifold Brace, as it was rattling. (apparently not a smooth move)
Looking at one of my old videos I see a missing bolt my oil dipstick used to stabilize on, and another piece of Steal that used to sit above Drivers headers, and maybe attache to AC/AC lines. (I still have brace form AC to Plenum Bolts attached.
AC seems secure. As u can image P/S Pump rattling like crazy till I get brace back on and new bracket in.
Old Oct 14, 2012 | 03:23 PM
fasteddi's Avatar
Car: 1991 Camaro RS
I understand. I once forgot to put the steel bracket on the back of the p.s and litlery broke the alluminum too. So needless to say those brackets are needed. Hope ya get her fixed up soon.
Old Aug 9, 2017 | 05:28 PM
Henjoe's Avatar
Car: 2 camaros, 1992 v6 /1984 350
Engine: 350 with holly carb swap to sniper
Transmission: Both are auto 700r4 both 1992
Axle/Gears: unknown
I desperately need this piece. what a pain. does anyone have one i can buy one from?
Old Aug 9, 2017 | 11:12 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
I had one break on me one time. Then I picked up another one from junkyard.That one broke as well and I picked up yet another one . So then now I have 4 broken brackets. May be different on your motor but on my motor the tensioner/belt was putting a lot of stress on this bracket causing it to break. So what i did was get a belt like two inches longer and never had the problem again. I had all 4 brackets aluminum welded for like 20 buks a piece at a machine shop. Might wanna try that route.
Old Aug 10, 2017 | 06:16 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
A longer belt can cause slippage and you can get squeal or lower output from all the accessories it runs.
Old Aug 10, 2017 | 05:33 PM
Henjoe's Avatar
Axle/Gears: unknown
i had mine aluminum welded by a friend. but my belt is the correct langth, AC delco part. i used to use the autozone brand bit ur right it was like 2 inchs short and it would keep braking my tentioner. 2 bolts holing the rear steering pump support snaped off, there manifold bolts. thast what im thinking lead to the bracket braking. heres to hoping if i replace the 2 snaped bolts it will support the bracket enough to not brake again. the friends told me the welds didnt come out very good and he doesnt think they will last. i desperately need a replacement
Old Aug 10, 2017 | 05:34 PM
Henjoe's Avatar
Axle/Gears: unknown
also i checked all the local jump yards, part yards, with in 2 hours driving time and no luck im really boned here.
Old Aug 10, 2017 | 06:24 PM
Mark RWC's Avatar
This yard is well organized and may have the part already pulled. Dorris Auto wreckers
Dorris Auto Wreckers
dorrisauto.com
3720 Depot Rd, Hayward, CA 94545 · ~11.7 mi
(510) 782-4392
Open until 5 PM
Old Oct 20, 2017 | 07:32 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I know I'm a little late to the party here, but don't you guys know there is a bolt that goes through the rear brace to where the fuel pump would mount on the engine if it was still carbed and the pump was driven by the cam? I don't even run that particular manifold bolt that the brace attaches to (well, the bolt is there holding the manifold on but the brace surely isn't attached to it). And you can't anyways with the PaceSetter headers as the flanges are too thin.
Oh, and an FYI... You can still get the non-A/C rear pump brace from GM but their stock is low. This part forces the use of the second head bolt hole in the front bracket next to where the bolt normally goes when A/C is installed.
Old Oct 26, 2017 | 01:50 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
No squeal and accessories all run great . Solid 14 v with car on. I have a few of these brackets if you guys are interested. I can do 40 shipped. Paypals best. I will upload photos.
Old Oct 26, 2017 | 02:00 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
On my setup the only thing holding the power steering pump up is two of the three bolts that bolt to the bracket. Then bracket goes on with only 2 bolts. The long one from top and the 10 mm on the bottom. That's it. Before with stock belt use to idle real rough. Power pump useto shake bad. To much tension. Thats why my bracket would snap. That and the lack of support from the missing bracket cause it to break. Getting a longer belt fixed the issue for me. Evryones set up is different. On my 6r i removed the smog pump and the ac compressor.
Old Oct 26, 2017 | 03:22 AM
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Transmission: THM 700R4
You mean like this? happened to me last year. Message Night rider327 he sells parts at reasonable prices as well.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
backtothe80s
Sep 5, 2015 12:39 AM
