Help what goes here?
Old Jan 15, 2013 | 03:13 PM
joeabate19's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6
The threaded thing. its at the back of the plenum, right in front of the distibutor. Thanks in advance guys. sorry im 18 and learning everything as i go.
Old Jan 15, 2013 | 03:30 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: Help what goes here?
I believe it is a purge valve. Not 100% sure, I haven't had a huge amount of time with the 3.1 top end.
Old Jan 15, 2013 | 04:08 PM
joeabate19's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6
Thanks. Do you know why it's threaded?
Old Jan 15, 2013 | 04:38 PM
Chad85T/A's Avatar
Car: 85 T/A
Looks like its threaded to screw a gauge onto it, like a fuel pressure gauge.
Old Jan 15, 2013 | 04:47 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Its just a tap for the fuel rail. Theres a cap that goes onto it. Like a tire valve cap but larger.
This is where you can see what your fuel pressure is.
Old Jan 15, 2013 | 05:49 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
^^ This.
Is just a test port, nothing is needed to go there, though a cap would be a good idea.
You can find caps to go on there on '95 to 2002 (maybe slightly earlier and slightly later as well), 3100 and 3400s in many FWD vehicles. Some are plastic, some are aluminum.
For reference these have the same thread as -4 AN fittings.
