Quick question about 3.1 to 3.4 swap
Old Jan 20, 2013 | 09:43 AM
Twessing's Avatar
Car: 92 Chevy Camaro RS
Engine: 3.1L V6
Im thinking about doing this swap but before i go and spend lots of money i am wondering if the harness is direct plug in. Ive done tons of research but no one has addressed anything about the harness. Will i have to pull the harness with the new engine or will the one that is in the car work. I have a 92'
Camaro 3.1l
Thanks!
Old Jan 20, 2013 | 10:23 AM
ex-x-fire's Avatar
Re: Quick question about 3.1 to 3.4 swap
The common swap is to use your(92) original intake, distributor, & exhaust manifolds on the 3.4L. Then you use the 3.4l injectors & the 92 harness.
Old Jan 20, 2013 | 08:58 PM
Twessing's Avatar
Engine: 3.1L V6
Sweet thanks alot!
Old Jan 20, 2013 | 09:05 PM
Twessing's Avatar
Engine: 3.1L V6
Another quick thing, If i get a 3.4 why cant i use the 3.4 exhaust manifolds? and will i have to worry about my driveshaft being to long or to short?
Old Jan 21, 2013 | 06:03 AM
ex-x-fire's Avatar
Engine bolts onto the same mounts, so no change in the driveshaft length.
I know on some engines like the 2.8/3.1 mpi engines, the exhaust manifolds have egr hook ups or other emissions fittings.
Old Jan 21, 2013 | 07:35 AM
Twessing's Avatar
Engine: 3.1L V6
Ah yes, that makes sense, Hopefully i dont break the bolts =/
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
reiderz iroc
Aug 13, 2015 04:57 PM
jahblah
Aug 12, 2015 05:54 PM
92projectcamaro
Aug 6, 2015 01:20 PM
