fuel rail
Old Feb 10, 2013 | 02:22 PM
92rsteal's Avatar
Car: 92 rs
Engine: 3.1l v6
Transmission: auto
fuel rail
hey ive had a few third gens in my life but i bought a 94 this time and i think the o rings on the fuel injectors r leaking its a 94 3.4l v6 what are the steps in pulling out the fuel rail hopefully with out pulling the upper intake
Old Feb 15, 2013 | 03:53 PM
project89's Avatar
Re: fuel rail
u have to pull the upper its a pretty simple task to do once u get the upper off there r 2 bolts iirc that hold the fuel rail down , once the bolts are out u will need a large screwdriver or small prybar to get the fuel rail up
Old Feb 15, 2013 | 04:45 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: fuel rail
But first why do you think the o rings are leaking?
Old Feb 15, 2013 | 08:24 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: fuel rail
They can leak for reasons of age, but often when someone is careless replacing an injector, they rip the o-rings putting them in. Particularly on the ones that go into the fuel rail- the holes in the fuel rail have very sharp edges. Use a little petroleum jelly on them prior to instillation...
Old Feb 16, 2013 | 01:38 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: fuel rail
I meant why does the OP think they are leaking? What's the symptom? Is there gas seeping from the rail anywhere?
Old Feb 16, 2013 | 06:52 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: fuel rail
If there leaking he would know it. I had mine leak before because I didnt seat them properly... it was a gassy mess.
Old Feb 16, 2013 | 11:26 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: fuel rail
Exactly. OP "thinks" they are leaking. No point pulling it apart if it's really something else.
Andrew6.688
Dec 13, 2015 10:59 AM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
