slight backfiring issue
Old Mar 23, 2013 | 09:20 PM
zaaac's Avatar
hello i have a 89 2.8 with a slight backfiring issue whenever im driving or idling it is okay but if i press the throttle abruptly like if i were to rev my car it would back fire when i press the throttle down, now i bought this car with a cat delete and some mickey mouse'd looking custom dual piping could that be the issue? also no check engine light or anything.
Old Mar 23, 2013 | 09:50 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: slight backfiring issue
Have you put a timing light on it?
Old Mar 23, 2013 | 09:59 PM
zaaac's Avatar
naw not yet all my tools are at the shop.
Old Mar 25, 2013 | 02:17 PM
zaaac's Avatar
problem solved. bad wire.
Old Mar 30, 2013 | 01:34 AM
KitCrusader85's Avatar
Car: 1985 Firebird
Engine: 2.8l
what wire did you find out was the problem I am having a similar issue...... probly plug wire?
Old Apr 8, 2013 | 06:23 AM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
My 3.1 backfires like a shotgun when decelerating off a freeway.
But mine is from a couple broken exhaust studs causing an exhaust leak.
Local shop wants $1000 to fix. Not gonna happen. After bills, every month I'm doing good to see $125. And that goes for gas and med co-pays .
Cornholio7979
Sep 20, 2018 02:31 AM
Prodigious
Oct 4, 2015 11:20 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
dyeager535
Aug 28, 2015 08:10 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
