Car loses horsepower and acceleration while driving
Old May 7, 2013 | 02:07 AM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
When I start the car and go almost right after starting and driving for 5 to 10 min and it has lots of acceleration and horsepower and shifts smooth, but after a few minutes it feels like the tranny is tight when it shifts and has a lot less power and acceleration. Is there any reason why it's doing this? It's also carbureted
Old May 7, 2013 | 09:16 AM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
Have you checked fuel pressure while hot? A failed o2 sensor failed coolant temp sensor and maf sensor will all do this. Also could be a short between your distributor cap and rotor. What have you checked and whats new
Posted from Thirdgen.org App for Android
Old May 7, 2013 | 12:12 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
Re: Car loses horsepower and acceleration while driving
It's carbureted so it doesn't have a maf sensor, but how do I check the fuel pressure? And if it was a failing 02 sensor wouldn't I be getting a check engine code? I did a tune up and the car starts a little rough and takes a few times to start sometimes, the cap was a little loose but I tightened it as much as I could, should I take off the cap and Rotar and do it agian?
Old May 7, 2013 | 12:19 PM
mcrandrz's Avatar
Car: 1991 camaro rs
I had a bad o2 sensor and it never gave me a ses light. Check fuel pressure at the check valve on the fuel rail should be 34-47.... Wait what year is your car.
Old May 7, 2013 | 12:41 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
Its an 84 2.8 v6
Old May 7, 2013 | 01:04 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Check fuel pressure before anything else
Old May 7, 2013 | 01:37 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
Okay, Do I need a special tool? And where is the fuel rail located?
Old May 7, 2013 | 03:24 PM
project89's Avatar
u have a carb car there is no fuel rail
the person that has been replying to u thinks u have a fuel injected car even after u told him it was carb'ed
how does the engine run overall, does it miss and sputter or does it idle nice and smooth and drive smooth?
by losing power what exactly do u mean, these v6 engines run better when they are cold , so as they warm up they lose a lil bit of power but not much
has the carb ever been rebuilt and is it the original carb ?
last time u did a full tune up, checked the ignition timing?
Old May 7, 2013 | 05:03 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
It Idles rough and will idle up and down. The engine runs but it feels like it is being choked or restricted when warned up, say if its cold and I press the gas all the way it picks up speed fast and has a little kick but once it's warmed up and I press on the gas it is a lot slower and feel restricted and has no kick. It is the original Carb and it has never been re built. I did a full tune up roughly 1200 miles ago but after the tune up the car didnt start up as well and makes a zinging noise when it does. And I have never gotten the timing checked, how do I do that?
Old May 7, 2013 | 05:25 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Your right I totally read right over that. My bad.
Old May 7, 2013 | 05:38 PM
project89's Avatar
u will need a timing light on ur car im not sure if the timing is ecm controled or not so somone a lil more knowledgeable will have to chime in on the exact procedure for u
for now pull out a few spark plugs and see what they look like they should be a light tan color
white or black is no good and will reveal if the engine is running out of fuel or has to much
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
kyleb24
Aug 15, 2015 08:24 AM
