Intake options.
Old May 7, 2013 | 04:18 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
Intake options.
Are there any options for aftermarket intakes on the 3.1 v6. Yes I know about the hybrid swap. But this is my daily so I can't just stop driving.
Posted from Thirdgen.org App for Android
Old May 7, 2013 | 06:56 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Intake options.
Only aftermarket lower intake made for the 60* is an Edelbrock. For carbs.
So you have 3 options:
1. Deal with it.
2. Downgrade to a carb.
3. Wait until you have the time and money for either a full FWD swap or a hybrid conversion.
Old May 7, 2013 | 11:03 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: Intake options.
Aw, it's a little better than that.
1. Downgrade to carb.
2. Used Truleo. lol...
3. Used Fiero DTB intake, if you have $800 laying around.
4. Fabricate pizza box, or similar.
Or just port the crap out of the existing intake.
Old May 8, 2013 | 01:45 AM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
Re: Intake options.
Aren't the iron heads just as much of a bottleneck as the intakes anyway? I agree porting is the way to go if hybrid isn't an option.
Old May 8, 2013 | 02:28 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: Intake options.
there's always the custom route...
Old May 8, 2013 | 05:05 AM
project89's Avatar
Re: Intake options.
intake is worse , moving air does not like to bend or change direction.
something like th epizza box intake ( upper plenum) fixes on huge issue with the stock intake
the stock lower plenum is actually a nice piece and with a lil bit of work flows great , its the mid and upper section that kill it
Old May 8, 2013 | 06:08 AM
mcrandrz's Avatar
Car: 1991 camaro rs
Eric thats on the hybrid isn't it? I'm in the process of saving up for a hybrid swap but I was just wondering. I guess theres not cheap options lol. Thank you I guess ill wait it out on the head swap
Old May 8, 2013 | 06:10 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Intake options.
If you really want great flow without a power adder, a hybrid is the way to go. I also want to do that. Ive ported the living out of my heads and intakes and im 100% positive a stock 3 gen head flows way better.
Old May 8, 2013 | 06:32 AM
project89's Avatar
Re: Intake options.
i can get them close , if i spent about 2-4 hours with the heads u have now i bet i can get u about an extra 50 hp or better. throw a set of custom manley valves and a few other ods and ends at them and ill get even more
Old May 8, 2013 | 01:06 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Intake options.
2. Good luck finding one. They're more elusive than the super-rare Hedman (I think) headers for our cars. And I think they were proven to be not much help?
3. Only if it will fit under the hood. Hasn't been proven yet.
4. Doubt his fab skills are up to par and welding aluminum is difficult for a beginner. Having one made would be more money than the stuff required for a hybrid swap, more than likely.
Porting would probably be a waste of time if he's going to go hybrid anyways, and it requires a decent amount of downtime, which he's trying to avoid at current.
Old May 8, 2013 | 03:59 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Intake options.
Agreed.
Old May 8, 2013 | 04:09 PM
ericjon262's Avatar
Re: Intake options.
no hybrid there, pure 3500. to be fair though, it's a Fiero, not a 3rd gen.
Old May 8, 2013 | 04:58 PM
mcrandrz's Avatar
Car: 1991 camaro rs
I guess ima save some cash. I want the hybrid anyway. Just seems awesome and the numbers dont lie
Old May 8, 2013 | 07:35 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Intake options.
hybrid is a awsome thing but if you can put a 100% 3.5L in a thirdgen... well then youll be doing what I dream of on a nightly basis...lmao.
Old May 8, 2013 | 08:24 PM
ericjon262's Avatar
Re: Intake options.
I don't see why you couldn't. I'd make a mid plate or the main side to side, and then a mount on the oil pan. wouldn't be too hard.
Old May 8, 2013 | 10:00 PM
caffeine's Avatar
Engine: 3500T
Re: Intake options.
I just have one mount on each side of the engine (3500). No mount on the oil pan required, and no engine movement . Swapping in a 3500 isn't really that difficult it's just that no one makes mounts for it and you either need to modify the oil pan or clearance the k-member for it.
All the necessary mods are really not difficult it's just time consuming, for example:
1) Modify oil pan, modify k-member, or buy tubular k-member
2) Make motor mounts (most difficult)
3) Upgrade to headers, slot holes in the stock exhaust manifolds, or find some FWD manifolds that fit (pretty sure two 3500 front manis would fit).
4) Drill/tap/plug extra water passage in RWD timing cover, cut off top 'ear' from TC cover
5) Flip intakes
6) Drill/tap LIM for CTS (I did it where one of the heater core lines comes out when FWD)
7) Figure out a new upper rad hose
8) Drill holes in accessory brackets to mount them to the heads properly
9) Upgrade to a 7165 or 7730 and make necessary pigtail changes/extensions/additions to stock wiring
10) Get an 88+ flexplate/flywheel if you don't already have one
11) Make/buy adapter for a cable throttle and use a W-body throttle cable
12) Buy external crank trigger
13) Tune!
VS hybriding the stock V6 which means
1) FWD Piston swap
2) Head/intake swap
4) Drill/tap LIM for CTS
5) Cut off top 'ear' from TC cover
6) Figure out new upper rad hose
7) Drill holes in accessory brackets to mount them to the heads properly
8) Upgrade to a 7165 or 7730 and make necessary pigtail changes/extensions/additions to stock wiring
9) Make/buy adapter for a cable throttle and use a W-body throttle cable
10) Buy a set of hybrid-length pushrods
11) Buy external crank trigger
12) Tune!
Missing anything?
Really, it seems like a hybrid is almost more trouble than it's worth over a full swap.
Old May 9, 2013 | 01:36 AM
ericjon262's Avatar
Re: Intake options.
well, with a mid plate instead of block side mounts, I feel like some kind of front support would be necessary.
Old May 9, 2013 | 07:28 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: Intake options.
2 thumbs up for a full 3500 swap...
Old May 9, 2013 | 07:39 AM
mcrandrz's Avatar
Car: 1991 camaro rs
What does a 3500 even come out of? And would a stock 700r4 off a 3.1 work?
Old May 9, 2013 | 03:05 PM
caffeine's Avatar
Engine: 3500T
Re: Intake options.
Stock 700r4 should work with some cutting to the plastic torque converter shield iirc. 3500s come in 04-06 Malibus, 05-06 G6s, 05-06 Uplanders/Montanas, and probably a few more I'm forgetting.
Old May 10, 2013 | 01:09 AM
caffeine's Avatar
Engine: 3500T
Re: Intake options.
Don't most people using a mid-pate setup use a front plate that mounts to the timing cover bolts? But that's way overkill for N/A and probably even turbo. Side mounts work perfectly fine.
Old May 10, 2013 | 07:58 AM
Engine: 450HP 355
Transmission: TH350
Re: Intake options.
Side mounts work fine, no need to go overkill for a V6.
My 3500 came out of a '04 malibu, just make sure to get a LX9 3500 and not the LZE gen 4 as they require even more work to swap.
Yes, bolts right to a 700R4. Use a flexplate for a 95 2.2L S10, and you'll have to cut the metal dust cover for the trans since the starter is on the other side. Takes like 5 minutes.
You will have to notch the stock K member, again that's very easy and won't take long.
My server took a huge dump a few weeks ago, i'm planning on getting it running again this weekend and when that happens all my 3500 install pictures will be back up in my thread.
Old May 10, 2013 | 03:35 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Intake options.
I look foward to seeing some pics deathstarr. I want to start a 3.5L swap this winter.
Old May 10, 2013 | 06:39 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Intake options.
I'm Six_Shooter and I approve this message.
Old May 10, 2013 | 09:57 PM
caffeine's Avatar
Engine: 3500T
Re: Intake options.
Looking for pics of anything in particular? I've got plenty on my build thread at 60*v6.com
Old May 11, 2013 | 08:24 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Intake options.
Mainly the trimmed K member and the exhaust routing. Not that I want to straight copy the exhaust but it gives me a good idea of what I would have in front of me.
Thanks man. Ill look for your thread on 60*v6.
Old May 11, 2013 | 08:58 AM
caffeine's Avatar
Engine: 3500T
Re: Intake options.
Ah I have a tubular k-member so no trimming in my car. Mars' thread shows k-member trimming IIRC. Although FWIW the tubular k-member makes working in the engine bay soooo much easier. My pre-turbo exhaust actually came from Mars' car as did my accessory brackets but there are plenty of pics in both threads. My power steering bracket is just a stock F-body/S10 bracket with an extra hole drilled in it and the alternator bracket is a simple custom setup that uses a J-body 3.1 alternator (nice small alternator).
Ill add as well that it just makes sense to go twin-scroll if building custom headers. Our firing order makes it relatively simple.
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
