is there a trick to this???
Old Jul 2, 2013 | 11:48 AM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
OK on my 92 rs 3.1 I can change all the plugs EXCEPT the passenger front. I've tried special plug sockets numerous extensions and elbows...other that witchcraft or removing the alternator bracket and ac stuff...how the hell you get it out?
Old Jul 2, 2013 | 02:31 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: is there a trick to this???
A swivel 5/8" plug socket and extension should do the trick. I've used a swivel extension and a regular 5/8" plug socket with no issues. Although, the swivel extension is a trick piece that years ago a friend gave me. Never saw one like it before or since.
The square end that goes into the socket is tapered (on the flats, along the length). Allowing the socket to pivot side-to-side on it. I have been able to grind an extension to do the same thing.
RBob.
Old Jul 2, 2013 | 03:47 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Those are readily available now.
Old Jul 3, 2013 | 02:01 AM
oil pan 4's Avatar
Car: 89 Firebird
If I remember correctly I had a spark plug socket at the time that had a hex end where the rachet drive goes in. I would put the socket by its self onto the plug and turn the socket with a wrench.
I changed the plugs a few times on my '85 V6 and remember it being simple and roomy.
I know I changed the plugs on my stepdads '91 V6 at least once and don't remember any issues.
But that was some time before 2001.
Old Jul 3, 2013 | 03:01 AM
Engine: 3.1 v6
ok Ethan's guys .
Old Aug 30, 2013 | 09:26 AM
Classicroute66's Avatar
Car: 92 Camaro
Engine: 3.1
I figured out a little trick. I was able to remove the plug with and extension but found it hard to hold it at the right angle when installing it. I took a piece of vacume line and stuck it on the top of the plug. Made it easy to "fish" in there and start the plug at any angle.
Old Aug 30, 2013 | 11:04 PM
91rs-t-tops's Avatar
Car: 91 Camaro Rs
Engine: 3.1 v6
I had trouble with mine as well i had swivels and so on trying to get after it. i just took the alt. bracket off and fabricated up a different bracket and now i can reach my hand down and pull the plug out if it falls out the socket and have plenty of room.
Old Aug 31, 2013 | 01:49 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you can always break the ceramic off and use a reg size socket
Old Sep 27, 2013 | 12:05 PM
Engine: 3.1 v6
I got it out.
just used a non spark plug sochet, a swivel, and an extension.
still backfires a little during deceleration .
Im thinking the broken exhaust studs are causing an exhaust leak leading to the problem.
all ignition parts have been replaced, seafoamed it about a month ago.
so...I'm chasing the gremelin causing this.
Old Sep 27, 2013 | 07:51 PM
Kingsobieski's Avatar
Best thing is to weld a nut to the top of the broken stud. (start the weld in the middle so it hits the stud and then work out to the nut). Anything else is a waste of time.
Old Sep 28, 2013 | 09:20 AM
excessiveego's Avatar
Car: 1988 Base Coupe
Axle/Gears: 9 bolt w/ disk brakes - 3.70
Originally Posted by Cadaver_Puncher
I got it out.
yes, if you have an exhaust leak and you only hear the noise on deceleration than that is your problem
timonator
Sep 30, 2015 12:52 PM
RS Reaper
Sep 27, 2015 07:04 PM
Justins86bird
Sep 27, 2015 09:43 AM
92projectcamaro
Sep 24, 2015 08:09 AM
project89
Sep 22, 2015 09:35 PM
