bad oil leak
Old Jul 15, 2013 | 01:35 PM
firechicken8292's Avatar
bad oil leak
Over the next week or so im gonna keep this thread updated. Basicly IMO i think this leak i commin from the base of the distributor. But i may be wrong here is a pic tell me what you think?
Old Jul 15, 2013 | 01:36 PM
Re: bad oil leak
Pic to large uploading to flikr or google
Old Jul 15, 2013 | 01:51 PM
Re: bad oil leak
Old Jul 16, 2013 | 01:11 AM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
Re: bad oil leak
Can't see the pic but it could easily be the o-ring on the distributor shaft. It's pretty cheap to replace at least.
Old Jul 18, 2013 | 04:25 PM
ItstillaV6's Avatar
Car: 92 Camaro RS
Engine: 3.1L(191ci) V6
Transmission: 700-R4
Axle/Gears: 3.23:1
Re: bad oil leak
Yes, you are one-hundred percent correct. The distributor shaft o-ring is a known issue, with the RWD 2.8, 3.1, and 3.4L V6s. Yes the 3.4L has a distributor shaft, just minus the distributor, and yes it leaks too.
There are two ways to correct it. 1. Get an o-ring for a V8 chevy distributor and use that. 2. And this is the one I recommend, as the ceramic coated reluctor coils are prone to failure on our stock V6 distributors, replace youer entire distributor. Autozone remans carry a lifetime warranty, and they have an improved reluctor coil design.
Plan on replacing the ICM every couple of years, as that distrubutor is in a terrible location to remain cool. NAPA's Eklin brand of ICM carries a 5-year warranty. Get one, install it, and make best use of that 5-Year warranty.
xxx3man`
Sep 23, 2015 10:37 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mike_c
Aug 27, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
drathaar907
Aug 6, 2015 04:20 PM
